- Nov 3, 2003
- 47,483
1. Reverse lights don't come on in reverse...thought it was a bad bulb, but nope.
Need to find the backup lamp switch for your setup.
2. PO apparently siliconed the side marker lights and screws into place, so my initial effort to remove the lenses failed. Have to figure out how to get the screws out an pry off the lens without breaking them.
Are you trying to remove just the lens, or the entire lamp assembly? It's one piece, so you access the bulbs from the rear at their twist-n-lock sockets.
When you remove the two screws the whole lamp should pull away from the body with the wiring in tow.
But you can access the bulbs without unscrewing the lamp assemblies from the body.
3. Drivers side rear marker light does not light up now.
Try smacking the body next to the light to see if that changes.
It's common for one or more of the side market lights to be dark. Sometimes twisting the wires and socket help, sometimes smacking the body will temporarily "fix" it too. Then sometimes the bulbs are just burned out.
No matter what though, if an old and a new one don't light up, you need to check for voltage to make sure it's at least reaching the socket.
All sorts of stuff can happen to those exposed lights over the years. The wiring is inside the wheel well after all.
4. Drivers side rear brake light is lit but does not flash/get brighter when brake is pressed...passenger side works fine.
That's a good sign at least. Shows that the brake switch up on the top of the pedal arm is working, and power is getting to it.
Does the driver's side turn signal work? If so, then it may be a faulty turn signal switch blocking the brake light signal.
Brake lights, hazard flashers and turn signals all run along the same wires and burn on the same bulb filaments after passing through the turn signal switch.
Because of this layout, your flashers will stop flashing when you hit the brakes, and your brake light is allowed to flash when you're on the brakes and hit the turn signal.
