Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 06/08/21, 09:43 PM   #1
Darryl M
Angie
Plug wire holders
Who sells the best looking spark plug wire holders. I saw some somewhere that ran along the bottom of the valve covers that were really neat. Does anybody know where I might find these? Thanks
Darryl M is offline   Reply With Quote
Old 06/08/21, 10:00 PM   #2
73azbronco
73azbronco's Avatar
Aridzona
Well, I tried three different versions, none looked as good as the pictures. I went back to a version of these from ford motorsport for simplicity and just cleaner looking:
https://www.ebay.com/itm/28310572804...BoCOSsQAvD_BwE
73 Explorer , 347stroker, NV4500 D20, Quadrajet spreadbore with manual altitude compensation, 4.1 ARB, Moser CTM Currie, 78 FSB disk brakes. 3.5 WH suspension lift, 2" Body lift for NV clearance.
Build here:http://classicbroncos.com/forums/sho...69#post1759569
73azbronco is offline   Reply With Quote
Old 06/09/21, 02:30 AM   #3
ransil
ransil's Avatar
western Pa.
I used in the past motorsport wires and separators, get 2 sets of separators.
ransil is offline   Reply With Quote
Old 06/09/21, 05:54 AM   #4
chuckji
SE Michigan
Wild Horses has these.
https://www.wildhorses4x4.com/produc...rmanceignition
Summit racing also has quite a large selection.
https://www.summitracing.com/search?...%20wire%20loom
69 U15 Sport LUBR, BluePrint 306, Holley Sniper, AX15, twin stick D20, D44, 9, 2.5 SL/1 BL, 31 on factory wheels
chuckji is offline   Reply With Quote
Old 06/09/21, 05:59 AM   #5
chuckji
SE Michigan
Im currently using these, which are similar to the Wild Horses except vertical orientation. Got them from Summit.
Click image for larger version
Old 06/09/21, 01:48 PM   #6
Rustytruck
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
I just use interlinking tye wraps for wire holders.
https://www.google.com/search?q=how+...r4-wTp16yoCg17
1974, stock 302, C4, BFG KM2 33x12.5x15, 8in rim, detroit rear, trutrac front 4.11 gearing, Warflairs,2.5" lift, chevy disc conversion, Hydraboost, owned since Christmas Eve 1977
Rustytruck is offline   Reply With Quote
Old 06/09/21, 02:22 PM   #7
chuckji
SE Michigan
That works too.
Old 06/09/21, 02:48 PM   #8
savage
Bronco Nut
savage's Avatar
god,family,country,4x4
Renton,wa
I set mine up this way.
ID:	525523   Click image for larger version
TAZ-74 bronco,302,c-4,dana20 and 3.5inch lift WILDHORSES
savage is offline   Reply With Quote
Old 06/09/21, 05:49 PM   #9
White Knight
White Knight's Avatar
Orange County, Ca
Wire looms
I used wild horse black aluminum separators
White Knight is offline   Reply With Quote
Old 06/10/21, 10:21 AM   #10
armynavy17
armynavy17's Avatar
Littleton, CO
I just used zip ties as well. Not perfect, but it works.
ID:	525568   Click image for larger version
ID:	525569   Click image for larger version
armynavy17 is offline   Reply With Quote
Old 06/10/21, 11:59 AM   #11
tabyers
I like these, without the brackets between
1969 w/77 Axles, 302, Carb, AX-15, D20, 44, 4.10, 2.5"WH
tabyers is offline   Reply With Quote
Old 06/10/21, 01:41 PM   #12
Bukin 67
Bronco Abuser
Bukin 67's Avatar
I ♥ being stroked
Southern California
I used these black anodized aluminum in-line wire separators. I think Summit sells them. Clean look with nothing bolted to the valve covers.
I personally like the look of the ones secured to the valve covers though. Sleek clean look but they would get in the way of my dip stick for one thing. I like to be able to easily move the wires to some degree if needed the way I'm set up.
"The Bukin'eer" 67 Sport. All unoriginal
Bukin 67 is offline   Reply With Quote
Old 06/10/21, 10:36 PM   #13
jckkys
Tucson, Arizona
I like the '80s Mustang plug wire looms. They're neat, out of the way, and not overly flashy. You need the front 6 valve cover bolts with studs that fit into the bottom of each loom. Here they are;https://duckduckgo.com/?t=ffab&q=198...Fhw0050__1.jpg
jckkys is offline   Reply With Quote
Old 06/10/21, 11:21 PM   #14
73azbronco
73azbronco's Avatar
Aridzona
My other issue with the fancy brackets, you cannot use spark plug wire hi temp boot protectors. The boots are to long. That and those brackets seem to me to hold the wires right over your header, while the simple separator leaned a little further away.
https://www.summitracing.com/parts/t...caAnyVEALw_wcB
Old 06/10/21, 11:22 PM   #15
73azbronco
73azbronco's Avatar
Aridzona
This, another reason wire brackets a no go, you are not moving wires very easily.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.57411 seconds with 72 queries
