Monday I pick up my rebuilt 302 from the machine shop. The engine has been out almost a year and a half and I have to figure out the detailed sequence of installing the transfere case cross member, Dana 20, and C4 from the bottom. Do I bolt the Dana 20 to the C4, jack it up (with or with out the crossmember attached, with one or both "L" crossmember support brackets already screwed into the frames?), Then support the front of the C4's weight until I attach the 302 (with what beside a jack if I want to still be mobile until I get time to installing the engine)? I know for a lot of you this wouldn't be your first rodeo. Unfortunetly the last time I pulled a trans and transfer case was for a clutch on a 3/4 ton Chevy twenty years ago). A list of the sequence you would use will be greatly appreciated. Thanks, John.
