Adding the dropped pitman arm would be ideal, otherwise you could remove the drop bracket for the track bar. In order to alleviate bump steer, you want your drag link and track bar to be parallel and the same length as one another. In order to minimize side shift of the body during suspension travel, you want your track bar to have as little angle as possible, hence the drop pitman arm being the best choice.
