I need to replace the exhaust on my 75 bronco. It currently has stock manifolds, which I intend to keep. From there back it has a rusted out dual exhaust system with an x pipe and glasspacks. It exits out the sides behind the rear tires.
It is quite loud and I want to simplify it all with a 2 into 1 system and one single flowmaster to reduce/eliminate the drone.
My truck is also stock height.
The only two (three?)off the shelf options I see, besides a bone stock set up, is the Duff's 2 into 1 and BC bronco with a magnaflow.
The duff's apparently won't work with a stock truck, as the front will hit the driveshaft without a 2 inch lift.
BC's setup is really the only other option I see, but it is incomplete without a tailpipe, and I don't want a magnaflow.
I would prefer to avoid stock since the pipes are smaller.
Anyone have a solution besides going with the BC and piecing it together?
