I have a stock 95 Bronco. I had the tranny rebuilt several years ago and shortly after, the speedo stopped working and the tranny started slamming into gears. I was told to check all the electrical connections. I unplugged and cleaned the rear speed sensor and the plugs to the tranny. It worked. 3 years later, I did it again. I've cleaned all connections. I replaced the ABS Module behind driver's headlight and I still had the Engine Light on and no speedometer. I am attempting to remove the front wheel sensors to replace them, but they are stuck. They looked simple to replace. I removed the single 8mm bolt and tried to pull them out. They are stuck. I soaked them with carb cleaned, tried to wiggle them and tried to get under the edge to maybe pry them a little. I got one to come out just a little with some wedging, but no further. Is there a special tool for these things? The manual says to remove the bolt and just pull them out... Buy the way, this is my First Post. Thanx for any help.
