I got a Comp Cams hydraulic roller cam for my 351. I asked for a super mild low end torque cam. No one, them or I discussed exactly what engine the grind was designed for. In use it runs like crap. I used the 351 firing order in routing the plug wires. Could the cam be a 289 or early 302 type? That would mean a different firing order. I did tell Comp Cams the cam was going into a 351. They may not have had a milder grind for 351s, so to give me the mild cam I wanted, they had to sell me a 289/302 grind. The fact that the engine runs at all with 1/2 the cylinders not firing in order is surprising. Has anyone had this experience?
