Thought I'd post a pic of the work in progress. Still lots to do.
Note, I was able to modify the stock throttle linkage to work by simply bending the bracket on the firewall and lengthening the adjustable rod out an inch. I bent the bracket toward the passenger side so the rod can move straight forward and back with the linkage on the throttle body. Even though it's a bit of an angle up and down, it seems to work smooth. I like this better than looping a throttle cable.
I currently have a low profile air cleaner with a base that is below the top of throttle body, using a 3" tall filter. I have a 1" body lift and the assembly is still too tall and keeps the hood from closing. I 'think' a 2" filter will allow it to fit and hopefully still give 'some' room at the top of the throttle body.
The top of the throttle linkage barely hits the bottom of the air filter base. Should fit if I trim the top of the linkage. I am using the second hole down from the top to mount the throttle linkage - so there should be no issues cutting off the top 1/2" - 3/4" of material.
Next up I'm going to build little L brackets mounted to the sides of the fan shroud so I can cut the shroud into two pieces making install and removal much much easier. Extremely hard to reach the fan /water pump pulley bolts otherwise... and since I may later upsize from 17" 5 blade fan to 18" 7 blade fan and/or downsize water pump pulley from 6.1" diameter to 5.5" pulley it will make that much less of a pain. I didn't overheat before, but it wanted to run a tad warm... that could have been due to the carb sucking in un-metered air through the throttle shaft. .. But the air flow at idle seemed to be less than stellar. I know I should just upgrade now, but my budget has already been blown by a lot so will just install and see.
Not so interesting story on water pump. Since the motor is a 5.8 / 351w with 1974 build date (obviously not original bronco motor), I looked for all the ford vehicles with that motor to match the water pump. Interestingly, other than some higher dollar aftermarket pumps, none of the replacement water pumps for similar year 351 came with the bolt hole right next to and above the lower radiator hose. The only water pump I found that matched up perfectly was from a 74-75 bronco w 302.
I'm guessing it would have been fine using one of the pumps that didn't have a hole for that bolt, but really didn't want to.
