Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 05/21/20, 04:00 AM   #1
Fry
Storing Bronco.
If I donít have a garage would it be a bad idea to store a bronco under a carport with a tarp?
Fry is offline   Reply With Quote
Old 05/21/20, 04:50 AM   #2
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
Our factory order
Ridgefield WA
The most damage I've ever done to my Bronco was by covering it for the winter. Anything that was alloy or chromed was corroded.
Now to be fair, it wasn't under a car port.
If I were to store mine under a roof, I'd use one of the non-weatherproof breathable covers, just to keep the dust off.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline   Reply With Quote
Old 05/21/20, 06:39 AM   #3
TNcowboy
If it's a carport you'd better use an outdoor rated cover.
Driving rain and snow and fog will still make it an outdoor environment
TNcowboy is offline   Reply With Quote
Old 05/21/20, 08:42 AM   #4
73azbronco
Too much time on my hands
73azbronco's Avatar
Aridzona
dont park it by a pool. My great idea carport cover is 10 feet from my pool, anything and everything rusts by the pool, I think due to the chemicals, not so much the water.
73 Explorer , 347stroker, NV4500 D20, Quadrajet spreadbore with manual altitude compensation, 4.1 ARB, Moser CTM Currie, 78 FSB disk brakes. 3.5 WH suspension lift, 2" Body lift for NV clearance.
Build here:http://classicbroncos.com/forums/sho...69#post1759569
73azbronco is offline   Reply With Quote
Old 05/21/20, 09:36 AM   #5
hyghlndr
Delaware ????
Get a breathable car cover, not a tarp.
hyghlndr is offline   Reply With Quote
Old 05/21/20, 10:35 AM   #6
1970 Palmer
Santa Ana
Under a carport to keep the sun UV off is a good idea.
But any kind of a soft cover, or tarp that touches the vehicle is a bad idea. The waterproof materials will hold moisture under the tarp causing damage. The soft breathable materials (meant for inside use) will hold dust and chaff the paint from wind.
As a vintage trailer guy, I have found no perfect solution to outside storage.
1970 Palmer is offline   Reply With Quote
Old 05/21/20, 04:20 PM   #7
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Yep, for sure....
sprdv1 is offline   Reply With Quote
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright © 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.46414 seconds with 66 queries
