75Denver
- Jun 5, 2007
- 571
Did you change all the rubber in the lift gate? Make sure you change out the little rubber piece on the "anti theft post" on the tailgate.
https://www.tomsbroncoparts.com/product/anti-theft-post-sleeve-tailgate.
I found the rattle was mostly between the tailgate and lift gate. That little sleeve seems to tighten things up. Buy a few of them, they tend to wear out and split.
I did. I even doubled it up thinking more is better. The latches have to be pushed down on the lift gate due to new dime size rubber bumpers (same with the tailgate). Did you completely remove your spare tire swing arm? Mine requires a decent amount of push to make it latch. I'm just running out of options. Starting to wonder if its somewhere in the latch mechanisms within both the tailgate and lift gate. Thanks for the input! Your Baja looks great as always.
