Thread Tools
Old 11/10/19, 09:49 AM   #1
oldiron
oldiron's Avatar
Gaze upon the light and see that it is blue.
Chattanooga
Which PCV?
I need some help on which pcv to use. There are a huge number of variations to choose from by application. This will need to be for my wifes '77...But it has an '86 ho engine, with a '70 2 bbl intake and '70 autolite 2100 carb and a c4.
This engine makes around 21 in hg at idle (if I remember correctly). The pcv I have in it now is a HUGE vacuum leak at idle (hard cold starts, off idle stumble, bogging etc) With this combination what would be a good /correct pcv valve (by application)?
With no pcv it idles like a dream..runs perfectly.
Any ideas?
Greg
'72 Wagon 302/3spd Seapine Green Poly.
'77 wagon 302 C4 unlifted, uncut, unmolested.
oldiron is offline   Reply With Quote
Old 11/10/19, 10:39 AM   #2
904Bronco
904Bronco's Avatar
So many Ford's, so little time...
Morgan Hill, CA
My guess would be to match the carb, pcv for a 70's bronco motor...
1967 Poppy Red U15 Lubr... 96 Explorer EDIS and NV3550
1971 Grabber Green U15 Lubr... 2000 Explorer EDIS and 4R70W
2016 Shelby GT350 - Race red
2002 F250 Superduty 7.3 212K and still going!
2001 Bullit Mustang. Son drives this one
904Bronco is offline   Reply With Quote
Old 11/10/19, 04:01 PM   #3
DirtDonk's Avatar
San Jose, CA
I would agree with 904. What model is in there now? Do you know if it was for the '77?
I wanted a 90 fitting so ended up with a '72 Chevy 350, non-LT1 model I believe.
Worked great.
The one I picked from a '74 Granada 302 was just like you describe yours to be. A huge vacuum leak.
The stock '71 302 worked fine, but had that vertical fitment rather than the 90, so I kept the GM unit.
Then again, there's always this... Bitchin Expensive PCV Valve
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 11/10/19, 04:34 PM   #4
oldiron
oldiron's Avatar
Chattanooga
Thanks paul. Ill try the gm variety.
Greg
Old 11/11/19, 10:56 PM   #5
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
Our factory order
Ridgefield WA
There's a lot more to it than just the angle of the nipple.
Since it's just a metered vacuum leak at cruise and full throttle, your jets may need changing if you change the flow of the valve.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is online now   Reply With Quote
Old 11/12/19, 11:30 AM   #6
DirtDonk's Avatar
San Jose, CA
That's why I tried six different PCV valves until I found the one that worked the best (35 years ago) testing each one on the vehicle to see which was the best match to the original.
For me it was ALL about the angle of the nipple. I knew there were differences or there would not be 48,001 part numbers all looking similar and fitting just fine. But I wanted one with a 90 degree nipple to clean up my hose routing.
The one with the most flow/leanest mixture was the one I kept in my tool box under the hood to swap out every time I got above 4,000 ft elevation on trips to the Sierras.
Saved me a lot of grief running rich at altitude, and hassle changing jets for just a weekend trip.
But then came fuel-injection... Problem solved!
Old 11/12/19, 05:37 PM   #7
vintage bronco
Hagerstown,Md
This is pricey but will solve all problems and they flat out WORK http://mewagner.com/?p=444 I put one on my 65 Cyclone 289 with 2/4bbl carbs and wow what a difference.
vintage bronco is offline   Reply With Quote
Old 11/12/19, 06:27 PM   #8
oldiron
oldiron's Avatar
Chattanooga
Wonder why nobody thought of something like this years ago?
Very cool.
Old 11/12/19, 08:19 PM   #9
blubuckaroo
Grease Monkey
Our factory order
Ridgefield WA
Very cool.
Actually, Paul did mention this years ago. In theory, it should lean the mixture, and help at high elevation.
Old 11/13/19, 12:14 PM   #10
DirtDonk's Avatar
San Jose, CA
I wonder how long the company has been making the "tunable" version in the link? It's pretty cool and, even at that price, I'm still tempted to try one even though mine are all working well with the engines they're installed on.
Old 11/13/19, 12:24 PM   #11
Lawndart
Lawndart's Avatar
Gardner, KS
I played around for a while trying to fine a good PVC valve.
I finally went with the Bitchin Expensive PCV Valve (aka M/E Wagner DF-17 Dual Flow PCV Valve).
Still happy I did.
Lawndart is offline   Reply With Quote
Old 11/13/19, 05:21 PM   #12
vintage bronco
Hagerstown,Md
You will not be sorry you did it they offer your money back if not happy but you wish you done it long ago.
Thread Tools
Page generated in 0.41976 seconds with 64 queries
