Jdgephar
- Joined
- Sep 25, 2012
- Messages
- 1,317
I went through the rear brakes on my 72 yesterday. When I put the new drums back on, I thought they would go on a little farther. It makes me wonder if I have the wrong setup on this axle.
Its a big bearing 9". No idea if it is stock to my 72. All of the parts I took off are the big bearing 11" drums and shoes for a 72, and I believe the backing plate is for the same. Bolt pattern for the axle matches the old style big bearing for 72.
Here are the pics. Does this look correct, or do I have some mis-match of parts? I'm used to the drum overlapping the backing plate a little bit more. Now, if it bolt up the drum, its about even.
Sent from my SM-G950U using Tapatalk
