coil springs
captgriz
islamorada florida
can anyone tell me if there are right and left coil springs. i didnt think it made a difference, but my passenger side coil spring rubs the front side of the upper coil bucket. it is a 2.5 inch lift. thank you for any input.
griz
langester
MASTER OF MADNESS
Should be the same. Have you checked the coil cups on the top of the radius arm. Sometimes they get bent out of shape and cause the springs to do strange things. Good luck with it!
Correct. No left and right spring on Broncos, like there are on some vehicles.
And since every Bronco is different, you may also be suffering from stacked tolerances.
Even with just a 2.5" lift you are shifting your entire axle towards the driver side, if you do not install a dropped trackbar bracket and dropped pitman arm.
That shift is usually not enough to cause a problem with 2.5" which is why it's still considered "not necessary" for lifts below 3 inches.
Plus, as mentioned your lower coil cup could be deformed from just general use over the last 50 years or so. Even the coil tower can be tweaked from use over the years.
There is always the possibility of a slightly deformed spring. But I've yet to hear of that happening, so it would be low on my list of suspects.
The other thing is the springs also bow out towards the front when a Bronco is lifted. This is because the radius arm design tilts the axle forward on the top, tilting the springs forward in the middle. This bowing can also impart a bit of twist to the coils, causing them to bow inward toward the frame as well.
Stacked tolerances...
C
captgriz
islamorada florida
thank you for the responses. i didnt think there was a left and a right spring so your confirmation is helpful. the lower coil cups are new and seem to be on correct. kind of crazy.
again thank you for your responses.
steve
Was going to say that with my 2.5 (and my 3.5 for that matter) I did not have the inward bow to the spring.
But now you've got me curious and I have to go out and look again just to be sure!
