Going to replace 1971 bronco speed cable and gear. Im seeing on tom bronco that the gears say for dana 20. I have a dana44. Do these fit ? Or anyone know where to get a gear from. Its 18 tooth. Tanks!
Hi, the transfer case is a Dana 20.
The speedo cable should work.
There are different gears for the speedo cable to accommodate different rear end ratios.
The Dana 44 is your front axle.
Good luck
