Replacing Floor Pans = Frame Off Restoration!
MidwestTexan
MidwestTexan
At this point I had it back to a rolling chassis and put the motor, tranny and TC on. I rebuilt the D20 and putting a HD output shaft on from WH. I ran into a few fitment issues. The alternator and d/s header were hitting the frame so I notched them. Then the remote oil filter would not fit as the alternator was in the way. I had to put the mustang timing cover and oil filter adapter which cured all that. Pushing forward!
ngsd
Just curious on why the fitment issues. I have not got this far yet and while I have only read other posts, there seems to be a lot of discussion that fitment is not an issue overall with certain aftermarket parts. Was something different on yours than those or what makes one work and not another? types of parts, who makes them, or even different conversions from 6 cyl Coyote? Just wondering since I am heading down this path.
MidwestTexan
MidwestTexan
Great question... There are a couple of factors that will cause/help with fitment issues which are motor choice and motor mount choice (there's other little things, that's the main ones I ran into). I went with a 2015 F-150 (Gen 2 and was $2,800) which has a different timing cover. The mustang cover puts the alternator up higher and you wont have to notch the frame (unless you use the KE motor mounts). You will however need to relocate the d/s gusset to the front of the cross member if you want to use the factory oil filter adapter. If not, you will need to use an oil filter relocation kit. Both are easily done. The second factor is the motor mount choice. I initially went with Krawlers Edge motor mounts which the motor sits about 2" lower than the Tumblin mounts which I ended up going with. The main reason I decided to go with Tumblin's mounts was I was concerned with the front end pumpkin hitting my oil pan. Tumblins mounts raised my motor up (also increased engine angle to 6.5*) and you wont have to notch the frame for the alternator. That leads to fitment issues with your brake system. With the Tumblin mounts, I was not able to use my vacuum brake booster system as the booster was hitting the d/s engine cover and I wouldn't have been able to pull my dipstick out. I ended up going with a hydroboost which solved that problem. Then if you go with another brand of headers for example, you may or may not have to notch the frame for them.
Like I said, every time I made a change upstream, it always impacted something downstream which had to be addressed. It's not difficult, just a bit frustrating, especially when you order something and think you've figured it out, just to find out you'll need to change it later.
My advice would be to use one vendor and stick with them. Their parts will all jive together. I used parts from Tumblin, KE, BC, Summit, Jegs, etc. I was able to save money going this route, but ran into some fitment issues as stated above. They are all great companies and you won't go wrong with whichever route you end up going. Feel free to PM as well if you have any questions. And good luck, it will be totally worth it!
ngsd
Thanks for the detailed response. This is great advice. While I am sure I will have many hurdles along the way, I am trying to learn from others about the pitfalls to avoid and really appreciate your experience being shared for all to learn from.
bronkenn
Bronco Guy
Southeast Ohio
I like the angle iron bracing. Getting ready to do the same. Question, I don't have a 2 post lift but I have an overhead hoist. Do you think the bracing is solid enough to lift the body up if you used points of of the bracing or do you think there is too much flex there?
I braced mine with angle across the bed and from there to the dash and used it to lift the body with no problemos.
MidwestTexan
MidwestTexan
bronkenn, that's a great idea! Looks like it would be much easier to replace the floor pans and kick plates. My braces were kind of a pain to work around.
MidwestTexan
MidwestTexan
Everything is basically mocked up. I'm going to raptor line the tub, under carriage and engine bay. I plan on painting the cowl, windshield, door jambs and dash. Then paint the rest of the body this fall. The paint is decent now so It'll do for the summer. I'm ready to enjoy this thing!
jmhend
Great job you are flying through that thing.
Sent from my SM-G930V using Tapatalk
MidwestTexan
MidwestTexan
Thanks for the kind words although I'm not really that fast. I started this build two months ago and I'm just getting around to posting pics and some details. I was so focused on trying to complete it that I didn't post anything. I did make notes in a word document so I'm just cutting and pasting! :) I will say the first 80% wasnt too bad... The last 20% is taking 80% of the time!
Here are some pics of the tub after I raptor lined it. I'm super impressed with this product. I have zero painting skill/experience... I think it turned out great!
sprdv1
REBEL
does look very good chief....
MidwestTexan
MidwestTexan
This is the point I'm at now. I finally got some parts back from the powder coater and I installed the WH extreme duty output shaft for the D20. I went with the hydroboost as the vacuum booster was hitting the valve cover and dipstick. I think I'll like the HB much better as I've read these newer engines don't make good vacuum. I'm going to raptor the inside of the outer fenders and the tailgate over the next few days. I'll also paint the cowl, windshield, dash and door jambs. Hopefully I can fire her up in the next 7-10 days!
MidwestTexan
MidwestTexan
I've narrowed it down to 3... White, Brittany Blue or Grigio Titans... I know, they couldn't be any different! haha I need to make my mind up by tomorrow and I can't make my mind up.
TX SS
Houston
The raptor liner looks really good. How much product did you use in total?
MidwestTexan
MidwestTexan
Thanks! It took 10 liters to do the tub, undercarriage and engine bay. I ordered two more liters to finish the tailgate and inside the outer fenders. One of the reps thought I could do it with 4 although there's no way that would have been possible. I only did two coats too.
jmhend
That Hydroboost bracket is my favorite fits like a glove.
