LORE Bronco restore
halogrinder
Houston
So, back story.
My pops bought this 1968 Bronco from Bob Lewis of Lewis Off Road enterprises back in 1972.
He drove it for a while, and blew the engine in '78. It's been in a garage ever since.
Yes, this truck has not been running longer than I've been alive lol
So, finally I convinced my dad to let me put the dang thing back together again so he can enjoy it.
I'm doing a restomod on this guy.
Should be a fun time :)
Here's a few pics of the race truck back in the day.
this truck was the chase/pit truck for the race trucks.
Truck will be painted original Chrome Yellow.
Undecided if we'll be doing a metallic blue hood or yellow.
This was the first truck sponsored by KC HiLites- that's pretty cool!
I've contacted a few other sponsors for stickers and/or vectors for us to reproduce the livery
Galpin Ford has one of Bob's trucks as well
71-mint-400-jpg.2631481
76-firecracker-250-barstow-ca-jpg.2631489
306b2small-jpg.2631497
306b3small-jpg.2631505
3051small-jpg.2631513
halogrinder
halogrinder
Houston
img_20170803_170448286-jpg.2665641
Pulled the dash
img_20170803_170421732-jpg.2665649
img_20170803_170415426-jpg.2665657
Replaced the floor pans because the driver seat holes were hurt, the passenger seat holes were ripped out, and a big patch was under the seat from something that got pushed thru from underneath
the passenger side seat holes didn't want to line up correctly- so I had to cut/mod the floor pan to make it all line up (better)
the center delta part actually fit better flipped over once cut off lol
I had to extend this forward about 3/8" of an inch. What a pain.
20191119_162307-jpg.2977720
20191025_154146-jpg.2977706
20191025_154209-jpg.2977708
20191025_155322-jpg.2977710
20191119_162253-jpg.2977712
20191119_162303-jpg.2977718
Undercoated, primed and sealed the rails under the pan
20191120_102532-jpg.2977722
20191120_163712-jpg.2977724
20200228_165811-jpg.2977732
Pain cutting these out and shifting them
20200228_165817-jpg.2977734
20200302_162706-jpg.2977738
Rebuilt the Tcase- Really just resealed it- everything looked 100%
20191218_163504-jpg.2977740
20191218_163526-jpg.2977742
20191219_175037-jpg.2977744
20191219_175045-jpg.2977746
20191219_175050-jpg.2977748
20191220_164249-jpg.2977750
20191220_164324-jpg.2977752
20191220_172053-jpg.2977754
Installed the NV3550 trans to replace the 3 speed.
20191223_154906-jpg.2977756
halogrinder
halogrinder
Houston
Started on the front end-
20200420_152446-jpg.2977758
20200420_152451-jpg.2977760
20200420_152455-jpg.2977762
20200420_152506-jpg.2977766
20200420_155638-jpg.2977768
Front core support was smashed up- so I replaced it
20200420_155645-jpg.2977770
20200420_155649-jpg.2977772
20200420_163951-jpg.2977774
20200420_172745-jpg.2977776
20200420_172741-jpg.2977778
pops nailed a palm tree and mushed up this body mount- I got it back to useable shape and height once the body was off.
20200420_172807-jpg.2977780
20200420_174441-jpg.2977782
20200429_170107-jpg.2977784
20200429_170112-jpg.2977786
20200430_145256-jpg.2977788
20200430_145301-jpg.2977790
20200430_145312-jpg.2977792
halogrinder
halogrinder
Houston
Cleco'ed in for welding
20200430_153813-jpg.2977794
20200501_121655-jpg.2977796
20200501_121902-jpg.2977798
20200501_151806-jpg.2977800
20200501_162246-jpg.2977802
then, started on the quarter panels.
Left side ended up looking like the flare had been ripped off 2 times, and had bondo in it. Right side looked good- so I ended up getting a spare set of Stroppe flares, welded the holes up and redrilled.
20200424_124351-jpg.2977804
20200424_124830-jpg.2977806
20200424_131530-jpg.2977808
Bed of the truck is nearly flawless.
20200424_143806-jpg.2977810
20200424_143813-jpg.2977812
Original suspension set up
20200508_130539-jpg.2977816
Had an antenna hole in the back, so took some time to clean this up and patch it
fb_img_1587822783176-jpg.2977842
20200424_150927-jpg.2977818
20200424_153915-jpg.2977820
20200424_153922-jpg.2977822
Cut the quarter out to get rid of the wasted/bondo/wavy sheetmetal
20200508_134256-jpg.2977834
20200508_144149-jpg.2977836
20200508_144157-jpg.2977838
20200508_144207-jpg.2977840
ended up using the shrinker to increase the body line radius to match the door shells better.
Yes, the pictures are uploading stupid, I know.
20200513_142916-jpg.2977844
20200513_154907-jpg.2977850
Rear quarter needed some more radius too
20200513_154805-jpg.2977848
20200513_160711-jpg.2977852
20200513_170441-jpg.2977860
20200513_162006-jpg.2977862
Got some steel for the rotisserie
20200508_144400-jpg.2977854
halogrinder
halogrinder
Houston
Made some supports for the body, and a frame for the body to sit on
20200612_122133-jpg.3107807
20200612_124617-jpg.3107808
20200612_124620-jpg.3107809
20200615_120000-jpg.3107810
1591987438653-jpg.3107811
then I felt like complicating things and wanted a hydraulic clutch
20200720_163026-jpg.3108734
20200720_163044-jpg.3108735
A creamer is the right size hole :D
20200720_165353-jpg.3108736
20200720_170238-jpg.3108737
20200721_104915-jpg.3108738
got some linkage stuff from the 'carr, and amazon
20200724_131457-jpg.3108739
Using another brake pedal eccentric for the pedal stop and return stroke adjustment.
20200724_165617-jpg.3108740
20200724_165633-jpg.3108741
20200724_165649-jpg.3108742
Yanked the windshield frame
20200518_173136-jpg.3107238
Pop's INSISTED on a stainless hinge. Ok. no problem.
Stainless acorn nuts too
20200526_161545-jpg.3107239
20200518_165408-jpg.3107241
20200518_165435-jpg.3107242
20200518_165420-jpg.3107243
20200526_161748-jpg.3107240
Made some windshield holder thingies
20200605_172742-jpg.3107245
20200605_172843-jpg.3107244
Rewelded the cage.
20200605_152835-jpg.3107246
20200605_153001-jpg.3107247
Made some B pillar tie ins
20200609_165259-jpg.3107248
I need help with these- I don't know what the hardware looks like to mount the Jerry can to this Dick Cepek baja gas can holder...... I'm assuming a j hook of some sort?
fb_img_1590075143472-jpg.3107251
found a skid plate buried in the parts.
1590072184075-jpg.3107249
1590072101961-jpg.3107250
Loaded the body up, and it's currently getting blasted then epoxy primered to seal the body. this was after hours of walking over the body inch by inch cleaning up welds, holes, flap disc/sanding them down
20200727_123100-jpg.3108743
20200727_125735-jpg.3108744
20200727_125841-jpg.3108745
Made some frames for the frame to roll around in the shop
20200727_171603-jpg.3108746
20200727_171611-jpg.3108747
Great story! And a great project to put together. Thanks for taking all the pics and making the time to share them.
I'm glad you can still do it for your pops. Lots of us have started doing the same thing, only to have the project take too long and dad not being able to enjoy it.
Looks like you're making good time so far. What kind of timeframe were these pictures taken during?
When you said "original Chrome Yellow" did you mean just that it was an original Ford color, of that your Bronco was Chrome Yellow? Sure does not look like it to me. From the underside dash pics and elsewhere, it looks to be more of a Reef Aqua or Caribbean Turquoise, or even Peacock Blue rig. Lot of Peacock's in '68 I think. Mine is too.
What's the color code on it the Warranty Plate? Or is that stuff still in existence?
Have fun. Keep the good progress and keep updating us as you can!
By the way, any identification on those shocks? I wonder if they too are vintage from the beginning? Could very well be.
They remind me of Burbank shocks (the bare shaft ones) and Gabriels (with the rock shield over the shaft) and it would be cool to get some info if any is left.
Part numbers would probably equate to Monroe or Gabriel, but if there are any decals left intact that would give the info.
ared77
Impressive documentation of your work, and impressive shop! Keep up the good work.
halogrinder
halogrinder
Houston
Thanks!
Yes, this has been a long process- and it's taken too long, so now I'm motivated to get it done.
I've played on this bronco in the garage since I was little- took about 36 years to pry it out of my dad's hands to let me put it back together.
Initially it was going to be a "just like it was" project like it had just sat there from the 70's and you stuck the key back in.
Then it turned into "lets put some disc brakes and power steering on it, clean it up a bit"
Then it turned into "gears would be nice, 5 speed would be nice, a big fun engine would be nice"
Then that turned into "if we're going to do it, we're going to do it right"
And it's continuing to snowball......so now I'm tumbling bolts and hardware to replate them in yellow zinc lol
Initially it came down- and a few weeks after it showed up, my wife goes "Im pregnant"......ok no biggie lemme knock this out in 9 months or less.
I didn't realize preggo time is pretty much game time for when baby shows up.
Then baby showed up.....
3 months later wife goes "I'm pregnant....again"
so, we had to fix that issue, AND I had baby 2 come along.
Now that both are up and running, I'm back to being able to spend time on it nearly daily......
So it sat for nearly a year and a half with almost nothing getting done before I could continue working on it.
I'm a Master BMW tech for 20 years now..... bodywork isn't my thing and it really hampered my progress. now that the body is out of my way I can get back to doing what I do best. Turning wrenches- which is moving much faster than I anticipated (I still got it :cool:)
To clarify on the color- Yes looks like a Turquoise and cream color was original factory colors.
Bob painted it Chrome yellow.
My pop painted it black.
We're turning it Chrome yellow again.
Yes, still have the VIN plate on the glovebox.
Yes, Paul- this is a literal time machine from the early 70's nothing has been touched since then. Heck, it's never seen daylight since 1978, until it came down here. I searched the part numbers and was only able to find this so far on one of the shocks.
I've kept one of each front and rear, but since I'm putting a 2.5" soft ride progressive spring set up in front, and a 9 pack long travel spring in the rear I know I'll be replacing them with different length shocks.
I'm unsure if I'm going with an emulsion King, Fox, or Bilstein. I may put reservoir shocks on, but that would only be for looks. Heck, I've considered using Gen1 or Gen2 Raptor rear shocks all the way around since they are internally bypassed and bump stopped.
I need to read off the numbers of the Gabriels my pics aren't good enough to do that.
Front Monroe's with the balljoint shaft ends were SSF 12387
screenshot_20200728-194335_chrome-jpg.3108780
screenshot_20200728-194305_chrome-jpg.3108781
thank you :D
tasker
all knowing of nothing
NH
awesome post!! that truck and story is amazing on so many levels!! thanks for taking us along!
toddz69
Wow! I had forgotten or not known that Uncle Bob had two race Broncos! I always assumed the one in those pics are the truck that Galpin now has. Your machine certainly is a time machine and you've done good work on it! (Love the E36 M3/4/5 in the background too!).
Gabriel shocks and Air Lift bags - those are certainly state of the art from when that truck ran.
I had one of those Dick Cepek jerry can carriers laying on my garage floor until a few weeks ago too. It didn't have any hardware with it either. I should go back in my old Cepek catalogs and see if I can find any illustrations that might help with figuring that out.
Looking forward to more in this thread.
Todd Z.
halogrinder
halogrinder
Houston
To be clear from Uncle Bob directly- "My race Bronco and the one that used KC lites for the first time in a race sits in the Galpin Ford Museum in Sepulveda, Ca. The only other Chrome Yellow Bronco I owned was a ’68 that was used for pre running for a short time. It was not a race car when I had it."
This is the '68 prerunner he's talking about
Yes, please if you have even pictures of the mounting that'd be great. I could reproduce them if i have to. My assumption is a J hook and a wing nut or something.
toddz69
OK - thanks for the clarification. From reading your first post, it seemed to me that you were saying the truck in those photos (race truck) is the truck you have.
Todd Z.
JeffG
San Antonio, TX
Nevermind the above. I had written this and forgot to submit. During that time, the question about the race truck was answered.
Either way, very cool.
halogrinder
halogrinder
Houston
Getting blasted and Epoxy primered
23142-jpeg.3108795
23146-jpeg.3108796
23144-jpeg.3108797
Not done to the level I wanted, so maybe Friday I'll go get the body. I picked up the other stuff today.
Guys, please do research on who you use to blast.
Please maintain expectations on both sides of the check you write.
I clearly didn't communicate the level I wanted the body cleaned and seam sealer removed.
Burned 3 hours of my life today going down there with a trailer, and will do it again on friday... sheesh.
