Classy Gauges
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 08/04/20, 08:53 AM   #16
markatherton
Beach City Broncos
San Diego
bronco
Awesome story. High quality work. Keep us posted...
markatherton is offline   Reply With Quote
Old 08/04/20, 08:59 AM   #17
JeffG
JeffG's Avatar
San Antonio, TX
Very cool project and history. Is this Bronco one of the ones in the race photo's? And if so, the body looks great for a race truck. It would be cool to restore it back as a racer to participate in the Pioneer Class:
https://classicbroncos.com/forums/sh...d.php?t=295213
69 Family Bronco, 77 In Progress
SOLD 73 Trail Rig/Crawler
JeffG is offline   Reply With Quote
Old 08/04/20, 09:01 AM   #18
Prizefighter
Prizefighter's Avatar
Dream big then build it.
East TX
I've been following you on Pirate. Great job and keep it up!
Prizefighter is offline   Reply With Quote
Old 08/04/20, 09:01 AM   #19
JeffG
JeffG's Avatar
San Antonio, TX
Nevermind the above. I had written this and forgot to submit. During that time, the question about the race truck was answered.
Either way, very cool.
Old 08/04/20, 08:03 PM   #20
halogrinder
Houston
Getting blasted and Epoxy primered
Not done to the level I wanted, so maybe Friday I'll go get the body. I picked up the other stuff today.
Guys, please do research on who you use to blast.
Please maintain expectations on both sides of the check you write.
I clearly didn't communicate the level I wanted the body cleaned and seam sealer removed.
Burned 3 hours of my life today going down there with a trailer, and will do it again on friday... sheesh.
halogrinder is offline   Reply With Quote
Old 08/06/20, 08:01 PM   #21
halogrinder
Houston
Got it back today. Gonna have to do some work that I've already paid for to be done- but its just not worth arguing with them. Fuck em.
The front skid plate had these torched out holes in it for some reason.
Fixed that up.
Powdercoater will see me on monday for a buncha stuff
Old 08/07/20, 06:15 AM   #22
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Always something ain't it.. Makin progress though..
sprdv1 is offline   Reply With Quote
Old 08/12/20, 07:53 PM   #23
halogrinder
Houston
took stuff apart.
Dropped it off at the powder coater.
Then I got to working on where the dude missed spots on the sand blasting :rubs temples:
Everywhere you see green is from me grinding something off he missed, and throwing some acid etching primer on there to cover the bare metal.
I have a few spots on the body that have a pin hole or something that I need to weld up and then its time to smear every joint/crack/seam with some Lord Fuser 123EZ seam sealer.
Bought some 5/8x18 threaded shaft so i can make extensions on my bearing puller to pull the bearings off the center sections and pinions.
then, off to the machine shop to use the rod honing machine and make some setup bearings so i dont have to press them on and off a bunch of times.
Ordered a few things here/there, waiting for them to show up.
some 3/16 and 3/8 hard line for brake and fuel lines, a 9" third member tool so I can set it up on the engine stand, and some other random things to keep me busy while I wait for powder coating to be done.
I've got a few different bodyshops that are giving me bids after inspecting the body on who's motivated to do it, who doesn't want to, and who's realistically going to do it within a reasonable budget, with a quality job.
Old 08/13/20, 12:09 AM   #24
DirtDonk's Avatar
San Jose, CA
Nice. Great seeing so many progress pics. Thanks for taking the time.
I know you're doing it as personal documentation for your project, but it's cool we get to share them too!
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 08/13/20, 06:29 AM   #25
sprdv1
REBEL
sprdv1's Avatar
Keep plugging away.. Just a matter of time
Originally Posted by halogrinder View Post
took stuff apart.
Old 08/13/20, 07:28 AM   #26
mrdrnac
mrdrnac's Avatar
Mesa/Show Low, AZ
Here are photos of the Cepek wingnuts and bent 3/8 inch bolt.
Click image for larger version
ID:	506475   Click image for larger version
Mrdrnac: 66 U13, 351C Engine, 4 Barrel-C/C heads, NP435 Trans, D20 twin stick, 4.56 Gears, Truetrac HP Dana 44 Front Axle, & Detroit Locker Rear. 37X14.5X15 Toyo Mud Country Tires,5.5"lift, 1" Body lift, Hydroboost P.B.,T Bird Calipers & P.S.(Mid Seventy's Chevy Van P.S.Box)
mrdrnac is offline   Reply With Quote
Old 08/13/20, 08:27 AM   #27
halogrinder
Houston
interesting. I figured it was something similar but this visual helps out a lot.
thanks!!
Old 08/18/20, 08:43 PM   #28
halogrinder
Houston
Yanked the column apart to replace the bearings, and clean it up.
Shaved the 3 speed fingers that came out of the bottom.
cut the shaft in anticipation for the flaming rivers ujoint setup I have but need to measure when its in the truck.
I got the old bottom bearing out by dropping the shaft in backwards, using a magnet to stick the steering wheel nut in there.... and bloop.
shaved the hole.
Off to powdercoat
Got my seam sealer in-
the dual tube gun i have doesn't fit.
sigh.
Had to get some 5/8x18 shaft and nuts to run the bearing splitter under my press so I could get the carrier bearings off.
Old 08/18/20, 11:23 PM   #29
DirtDonk's Avatar
San Jose, CA
Very creative press fixture!
Is that a Dana Power-Lok (or Powr-Lok, or Powerlock, or whatever lock!)?
Old 08/19/20, 06:20 AM   #30
sprdv1
REBEL
sprdv1's Avatar
Great shots of all the little things getting taken care of..
Keep up the good work
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.51817 seconds with 71 queries
