Thread Tools
Old 09/11/19, 03:33 PM   #1
TTownEP
TTownEP's Avatar
Daphne, AL
Explorer serp tech help
I am trying to wrap my head around this power steering pump system.
I have a 4x4x2 box (previous owner installed) and I have it adapted to -6AN male with a 90 degree fitting (also from the PO so I don’t know where it came from) so that end is good to go.
I had my local shop make me a high pressure line with -6AN females on each end.
I have the Russell 16mm to -6AN male adapter from Summit on the pump.
I cannot seem to find a 90 degree fitting to go from the male fitting on the pump to the female fitting on the hose that isn’t made of aluminum, like these. I need to turn off the top of the pump to head down towards the box.
Can I use aluminum safely? Does anyone know of a steel version?
Here are the fittings I scavenged from the old pressure hose. The 45 degree bent one that says pump is what I need to replace.
1972 Wagon - @RHBronco - Instagram
TTownEP is offline   Reply With Quote
Old 09/11/19, 05:16 PM   #2
sykanr0ng
sykanr0ng's Avatar
"You say overkill like it's a bad thing"
Greeley, CO
Tom Lee (of Lee Power Steering) has stated that the 90 degree fittings like that blue one restrict the flow too much and should not be used.
The ones with the tubing bent in a curve do not restrict the flow.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation or authenticity...My Dad called that sick and wrong
www.coloradoclassicbroncos.com
sykanr0ng is online now   Reply With Quote
Old 09/11/19, 06:20 PM   #3
garberz
Bronco User
garberz's Avatar
Clear me a path...
Conejo Valley, Ca.
Yup, you need sweep style 90ís. And they need to be steel. PS pumps can produce over 1500 psi, those aluminum fittings arenít up to holding that kind of pressure.
Mark
EFI, OBDII, 5.0, C4, AtlasII 3.8. 5.13ís, HP44, Detroit's, 37ís, Duff Long Arms, 5.5" coils w/adjustable mounts. 2 3/4Ē suspension lift.
garberz is offline   Reply With Quote
Old 09/12/19, 05:58 AM   #4
KBUCK1
KBUCK1's Avatar
Williamson
I made my hoses with fittings from summit
KBUCK1 is offline   Reply With Quote
Old 09/12/19, 09:59 AM   #5
TTownEP
TTownEP's Avatar
Daphne, AL
I have dug through pages and pages of Summit fittings and haven't found anything like that. Weird.
edit: well, ones that aren't a hose end. My hose is already terminated with -6 females. Maybe I need to scrap it and just make my own hose.
Old 09/12/19, 05:02 PM   #6
SteveL
Huge chevy guy
SteveL's Avatar
66 &72 w/351, 4spd, 4whl disc.
Hawthorne, ca
Is the tight 90į fitting flow an issue on the return?I added the bc fluid cooler and I think it came with a tight o0.
SteveL is offline   Reply With Quote
Old 09/12/19, 05:08 PM   #7
DirtDonk's Avatar
San Jose, CA
We have these kits (#2053 and #2081 on this page: https://www.wildhorses4x4.com/catego...csteeringparts) for rolling your own.
All you need are the adapter fittings to whatever pump and box you're using.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
DirtDonk is offline   Reply With Quote
Old 09/12/19, 06:54 PM   #8
garberz
Bronco User
garberz's Avatar
Clear me a path...
Conejo Valley, Ca.
This is the way to go, and the prices are competitive with most any other place online.
Mark
Old 09/13/19, 12:48 PM   #9
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
I have a 4x4x2 box (previous owner installed) and I have it adapted to -6AN male with a 90 degree fitting (also from the PO so I donít know where it came from) so that end is good to go.
I cannot seem to find a 90 degree fitting to go from the male fitting on the pump to the female fitting on the hose that isnít made of aluminum, like these. I need to turn off the top of the pump to head down towards the box.
You will probably have pressure issues. The Explorer pump is well known for being finiky about the adaptor that is screwed into it. The adaptor from Lee's Power steering works, most others do not. They hold the relief valve open so no pressure can ever build or something like that.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
Why do people keep expecting "normal" from me?
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is online now   Reply With Quote
Old 09/13/19, 01:16 PM   #10
KBUCK1
KBUCK1's Avatar
Williamson
I believe mine is the Russell fitting also. I do know it came from Summit. Haven't had any problems. I could just be lucky though. I have heard of there being problems though
Old 09/13/19, 05:05 PM   #11
TTownEP
TTownEP's Avatar
Daphne, AL
I didnít read about those issues until I already had it in hand. At least I will be in the know if it gives me trouble.
Old 09/13/19, 06:22 PM   #12
DirtDonk's Avatar
San Jose, CA
I don't remember ever hearing of any issues with our fitting either, but you guys tell me if I missed any.
On this page: https://www.wildhorses4x4.com/catego...eyword=fitting I believe it's the #2068 but I'd have to look it up to be certain.
Thread Tools
Copyright © 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.32512 seconds with 65 queries
