SpareParts
- Nov 13, 2004
- 5,592
Lawn mowers have great switches under the seats.... I'm sure you can find them cheap! LOL
The seats look good. Will it be at OCBR? If so, I may just have to ask to sit in them!! LOL ;D
Nice job on 'ol Yeller, Great planning w the frame and cage, I'm impressed. does it squeak w the body bolted straight through, [sandwiched ] between the cage and frame mounts? The body is off mine and I keep looking at the mid section, back. Thinking about how to tie the cage in along with a 2" body lift, I hate those plastic pucks, upper coil-over mounts, a frame designed for leaf springs, and think the factory frame is in the way and just want to cut it all off! Or, maybe cut it in front of the under seat body mounts and move the frame up 2" and weld it back up. Or, build a new frame that fits the under side of the body and weld that to the front half and sandwich the body between frame and cage. Or, focus on the fact it's not a KOH rig/tube buggy and put it back together. Or...., I'm stuck.....Yours is killer, like the GM drivetrain.
The rear links are 36" center to center. As for how close to the tcase yolk I reall have no idea as long as the Tcase isn't mounted way above the link mounts its really not a big deal, its low enough that it doesn't even run a CV on the driveshaft just a standard joint, to get the pinion up more out of harms way at ride height the pinion is up past straight instead of the tcase output and the pinion being parrallel, the pinion is rolled up so the angles match at the tcase and pinion yolk, basically a long CV joint, so it doesn't vibrate. OK thinking back to machining class..... Y axis.... The answer is yes, almost, they are very close. My rule of thumb on the rear for the Z axis is at the frame 50% of the axle distance, worked that out years ago with lots of trial and error before suspension calculators.
Yes 9/16 bolts are more than sufficient, in 20 years I've seen 1 broken one and it was obviously defective on a brand new build. If worried use F911 bolts, they are aircraft grade and traceable, expensive but worth it if your concerned.
As for answering questions for total strangers..... If I can help you build a better working, stronger, more reliable rig than if we ever do meet then we get to spend time wheelin and covering ground rather than struggling and wrenchin;D
And thank you for the compliments, I'm just a knuckle draggin fabricator that builds stuff that goes forward.
Looking good Steve... I might need a new set of seats along with Adams rig also....
... The idea was I wanted a large flat roof that I could put an aluminum safari roof on. ...
Thanks Ken!
Missed you last week, we managed to have fun without you
The stance is easy, lift the front enough to level it out, bolt on some big tires and wittle away at the sheet metal till they fit, or just throw away all that bronco stuff under there and build from scratch...
