- Joined
- Nov 12, 2011
- Messages
- 1,311
New rear shock mounts to provide an alternative way of mounting a single shock in the forward leaning position.
Can also be used in the stock rear position with removal of the factory mount and provided there is enough clearance under the body.
This is an updated design of the previous version, I made a few minor changes and they are a little lighter as well. They are meant to be welded on.
They are designed to fit a longer than stock shock and will work with a 1" or taller body lift. A 1" lift will require minor trimming of the lower wheel tub lip under the floor, any body lift taller than 1" should not require any trimming.
The mounting base could also be cut down to allow for fitment with no body lift.
The mounts are tilted upward slightly to better match the angle of the shock.
Shock length will ultimately depend upon suspension lift and travel, where the rear axle is positioned and location of the upper and lower mounts.
The shock mounting tabs have an 1-1/2" inner spacing and holes for 1/2" bolts.
They are only available as bare steel, You will need to to paint or coat them as You see fit.
Lower shock mounts are not included, there are many options out there and differing ideas on how and where to fit them.
+++Please be advised, if planning on using Bilstein 7100 model shocks with remote reservoir, there can be clearance issues that may need to be dealt with due to the hose fitting angle where it exits the shock body.+++
Sold in sets consisting of a left and right shock mount.
The price per set is $225.00 plus shipping.
Please send me a private message if interested or with any questions. Thank You.
I try to keep a set or two on hand ready to go. otherwise, I do typically try to have the components ready to go together so I can get them out quickly as needed. The pictures shown on the rusty frame are for reference, actual positioning would be determined by purchaser/installer.
