Thread Tools
Old 06/14/19, 02:56 PM   #1
jasonmcc
jasonmcc's Avatar
Nola -> Utah
Choke stuck
I have a Holley street demon carb that I've only had for a few months. Today I noticed that it was running bad, it would die on me if I tried to climb any hill in 1st gear and overall seems to be running erratically. Is my choke stuck open and if so why does this happen and how do you fix this? I tried slightly unscrewing the three bolts on the electric choke to adjust it but it didn't seem to make it move at all.
https://youtu.be/Qe7wEYKS3jg
76' Bronco Sport
jasonmcc is offline   Reply With Quote
Old 06/14/19, 04:23 PM   #2
B RON CO
B RON CO's Avatar
still workin' on it
Long Island, NY
Hi, when the engine is warmed up the choke should be held wide open by spring pressure, and snap open when you try to close it.
The adjustment is for when the engine is cold, and richer will make the choke stay closed longer.
I don't think the choke is the problem.
So it was not making power in first gear.
Was it popping, just not revving up, or something else?
How does it drive now?
Running in the driveway is very different from driving under load.
It could be in the carb, maybe float level, stuck float, dirt, or weak fuel pump, or clogged filter.
Good luck
B RON CO is offline   Reply With Quote
Old 06/14/19, 04:50 PM   #3
jasonmcc
jasonmcc's Avatar
Nola -> Utah
Good luck
So it Boggs down like itís starving for fuel. I cleaned the fuel filter and it seemed to help. What are people recommending for fuel filter between pump and tank? I currently o lot have one between pump and carb.
76' Bronco Sport
Thread Tools
Copyright © 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.29283 seconds with 60 queries
