Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 12/18/19, 10:30 AM   #1
jduffent
jduffent's Avatar
Bronco born and raised
Knoxville, Tennessee
Hellwig Sway Bar now available at James Duff
Purchase your Hellwig Swaybars by December 31st to qualify for a $35.00 rebate per swaybar up to 2 bars. This means you can get 70 bucks back if you purchase a set from James Duff.
Front Sway Bar is here:
https://www.dufftuff.com/Hellwig_Fro...nco_p/5311.htm
Rear Sway Bar is here:
https://www.dufftuff.com/Hellwig_Rea...nco_p/5313.htm
These swaybars are a key component of our new Duck Tuff 2.5" lift that we will be talking more about in 2020. For now, you can read more about it on our website:
https://www.dufftuff.com/DuckTuff_2_...p/ducktuff.htm
http://www.dufftuff.com
The Bronco Specialists since 1967
865.938.6696 m-f 10-6 EST
Now: Knoxville, Tennessee (Exit 110 off 75)
jduffent is offline   Reply With Quote
Old 12/18/19, 06:18 PM   #2
SteveL
Huge chevy guy
SteveL's Avatar
66 &72 w/351, 4spd, 4whl disc.
Hawthorne, ca
Does the front kit fit with your stage 2 front hoops?
SteveL is offline   Reply With Quote
Old 01/01/20, 12:01 PM   #3
fordtrucksrule
fordtrucksrule's Avatar
SoCal Highland
Question regarding this sway bar. How does the bar mount? Do you have any photos?
351w with a rv cam. pumping 300ft./lb torque at 2000 rpm and 160 hp at 3500 rpm to the ground with 4.11 and 35" tires ZF Transmission and a StAk 3 speed t case 133:1 crawl, full family cage, rhino lined tub.
fordtrucksrule is offline   Reply With Quote
Old 01/01/20, 09:38 PM   #4
Monster Mike
Monster Mike's Avatar
always innovating constantly evolving
Knoxville, TN
We have not installed them with hoops on our in house Broncos yet.
We just started offering them. They are part of our new Ducktuff suspension system we just came out with. That system does not use hoops.
Our customers have reported mixed results using the Hellwig sway bar with our hoops. Some have no issue while others have had to slightly bend the sway bar out to clear them.
If you would prefer a more definitive answer from us directly we will be test fitting here at the shop in the next few months.
MM
Product and Warehouse manager at James Duff Inc. The Bronco Specialist since 1967. You want Quality American made Bronco parts? Then give us a call at 865-938-6696 or check us out at dufftuff.com James Duff Now in Knoxville, Tennessee. Open 10-6 Mon-Fri EST. YouTube channel - Bronco Garage
Monster Mike is online now   Reply With Quote
Old 01/01/20, 09:40 PM   #5
Monster Mike
Knoxville, TN
Here are the install instructions. There are photos in them as well.
https://www.dufftuff.com/v/vspfiles/...tions/5311.pdf
MM
Old 01/08/20, 04:16 PM   #6
jmhend
jmhend's Avatar
Bethlehem, PA
Mike,
I called today about the sway bar fitting Duff suspension (TRex arms, 3.5" deluxe suspension with hoops) and I was told they will NOT FIT. I could wait a few months for testing in house if that is the case but was shocked to hear they didn't fit with your suspension. I will stay tuned for test results.
MM
jmhend is offline   Reply With Quote
Old 01/14/20, 05:15 AM   #7
Monster Mike
Knoxville, TN
Originally Posted by jmhend View Post
Mike,
Our canned response is to tell people they don’t fit with hoops. Not just ours. This is because it’s hit or miss and we don’t want customers returning the product.
Keep in mind we added the Hellwig sway bars for our new Ducktuff lift which does not use shock hoops. More info here: https://www.dufftuff.com/DuckTuff_2_...p/ducktuff.htm
If you have the ability to bend the sway bar you can roll the dice like others have.
If not, we will get you definitive answers soon
MM
Old 01/18/20, 10:27 PM   #8
RuggedOverland
Newbie
Battle Ground
I just got done installing my front Hellwig sway bar with stock height suspension and the fit and finish is spot on! I have been running them on my Jeep for a number of years now and also on my wife's Yukon. Im excited to get the Bronco back on the road to see the impact!
RuggedOverland is offline   Reply With Quote
Old 01/20/20, 07:50 AM   #9
jduffent
jduffent's Avatar
Don't forget to leave us a review on DuffTuff, you'll get a chance at $100 duff bucks, our next drawing is at the end of March!
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.44860 seconds with 65 queries
