Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 01/11/21, 11:02 PM   #31
bronconut73
bronconut73's Avatar
How did you do that?
Orlando
This might be for Blu's Falcon/Ranchero build.
If so I do not believe the Explorer PS pump will fit under the hood anyway.
March always used to sell a sbf serpentine pulley/bracket set. I'm sure they still do.
'73, 3.5" sl, XL RS9's, F-250 mounts, Duff long arms, 1" bl, 35" MTZ's, C-4, twin sticked, P.S., built 351W, Exp Serp, F&R Detroits, 4.11's, chromo axles, 11 leaf packs, SuperJoints, Chevy front disc, BC rear disc, BC Vintage a/c, Scat Procar 2K seats, Alpine/Pioneer, Bear, Cobra 148 GTL/Texas Star.
bronconut73 is offline   Reply With Quote
Old 01/11/21, 11:07 PM   #32
73azbronco
Too much time on my hands
73azbronco's Avatar
Aridzona
Originally Posted by Madgyver View Post
I recall searching for a clutch fan that will work with the serp set up as there are several options with the fan depth into shroud.
The answer is explorer steel fan which gives you the heavy duty clutch which sits about 1-1.75 back from rad and at least half way into WH shroud.
73 Explorer , 347stroker, NV4500 D20, Quadrajet spreadbore with manual altitude compensation, 4.1 ARB, Moser CTM Currie, 78 FSB disk brakes. 3.5 WH suspension lift, 2" Body lift for NV clearance.
Build here:http://classicbroncos.com/forums/sho...69#post1759569
73azbronco is offline   Reply With Quote
Old 01/12/21, 06:48 AM   #33
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
Our factory order
Ridgefield WA
Originally Posted by DirtDonk View Post
Mark, with the resistance to change you have on some items, and your normal recommendation to stick with V-belts, why are you even thinking about a dual-belt serpentine setup? Are you missing some of your original parts at this point? Is the new engine going to be a 28oz or a 50oz engine?
If it's just to keep with a standard rotation pump and fan, then why not stay V-belt for less cost and more fan clearance? If it's just to keep the mechanical pump, then why not stick with V-belts for the same reasons?
As has been said, the V-belts work fine for most situations. If you need more grip due to a larger alternator upgrade (you are not planning that as well, are you?) then workarounds have been figured out for that two. Just run a larger alternator pulley, or a dual-groove alternator pulley.
I'm just asking because adding serpentine at this level seems like a huge waste of money just to have less, or certainly no more than normal, room for your fan near the radiator.
Seems like there was a discussion about this just a couple of months ago with pictures and discussion about clearances. Was that your thread Mad? If not maybe someone's got a link to it if you missed it the first time around.
Maybe I'm off base and the clearance issue is not that big a deal with certain kits, but it seems like it would be on most of them.
March Performance used to be the go-to for serp systems, but at least back in the day they were too long for Broncos. I've heard that since then they have added some lower profile kits that would offer more fan clearance with the radiator, but have not looked into them.
I agree Paul. I'm keeping the v-belts and 1G alternator in my Bronco. It works great.
This new motor is going into my '62 Ranchero project. I'm pretty much starting from scratch. My Blueprint engine just has the old style timing cover.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline   Reply With Quote
Old 01/12/21, 07:06 AM   #34
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Originally Posted by markw View Post
The Sanndamann3 kits are complete with the very specific bolts you need. Usually need to be cleaned up and painted, replace the pulleys and away you go. Easiest route to the goal.
Originally Posted by 56f100bbw View Post
Sanndamann3 I got 2 Complete serpentine set ups and all the brackets were detailed I didnít have to do anything to them they look great
sounds like a pretty good deal...
sprdv1 is online now   Reply With Quote
Old 01/12/21, 07:12 AM   #35
blubuckaroo
Grease Monkey
Our factory order
Ridgefield WA
Yes, this engine will be going into my Ď62 Ranchero. Itís tempting to put it into our Bronco, but the power curve would be way off for the way we use the Bronco. Why donít you think the power steering pump would fit under a Falcon hood?
Old 01/13/21, 12:01 PM   #36
Madgyver
Bronco Madman
Madgyver's Avatar
RADIO FLYER ROCKS
Honolulu,Hawaii
eBay: madgyver
Here is a side by side pic. CVF on the left. Explorer serp on the right..
Click image for larger version
ClassicBroncos on the rock....
My builds. Click links below for pics.
Yellow77 redo...
Green77...
Taz's FireBronco...
Madgyver is offline   Reply With Quote
Old 01/13/21, 09:53 PM   #37
blubuckaroo
Grease Monkey
Our factory order
Ridgefield WA
Thanks. CVF looks to be a lower profile. I'll need that!
Old 01/14/21, 01:08 AM   #38
Madgyver
Bronco Madman
Madgyver's Avatar
RADIO FLYER ROCKS
Honolulu,Hawaii
eBay: madgyver
if I had to choose, I'd go with the explorer front dress everytime.
I have put together both of them and the explorer front dress is soo much easier with less parts that does the same thing. It is also much closer to the face of the block which allow for more fan options. The CVF kit I know i will have limited space to the radiator.
The CVF kit is nice though very pricey. They do have warranty on the parts and equipment but it won't be something that I can pick up at your local auto parts store.
Yellow77 redo...
Green77...
Taz's FireBronco...
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright © 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.46498 seconds with 70 queries
