Dfroman
- May 11, 2011
- 135
Hello,
Just got my 76 bronco back from getting rewired.
they removed the column and dash.
At first it was just popping from reverse to neutral. Now it is going from reverse all the way to first or low.
I have a flaming river tilt column and a 6r80 trans using modified stock shifter linkage.
I have taken the wheel and adapter off and turned with a wrench and have the same results. I do not see anything near the steering shaft that is putting pressure on the shift collar.......
Could this be bad bearings in the column?
the shifting with the steering has made the Bronco underivable.
Thank you
David
Thank you
David
