Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 06/06/19, 07:45 AM   #1
twood9mm
Newbie
so cal
AOD install. Any recomendations
I am in So Cal. I am getting quota up to $5500 for removing my C4 and installing AOD E. Does anyone have a
Recommendations for more
Reasonable shop. Redondo beach
twood9mm is offline   Reply With Quote
Old 06/06/19, 08:07 AM   #2
gddyap
gddyap's Avatar
Mtn View, CA
Does that include a brand new AOD or just labor? What shops have you gotten quotes from?
gddyap is offline   Reply With Quote
Old 06/06/19, 09:03 AM   #3
broncobsession
Not a bronco guru
broncobsession's Avatar
All Over the Place
Wow that seems high.
Always looking for the next project.
broncobsession is offline   Reply With Quote
Old 06/06/19, 09:46 AM   #4
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
That sounds like a "I don't want to do this job" quote.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
Why do people keep expecting "normal" from me?
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline   Reply With Quote
Old 06/06/19, 09:49 AM   #5
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
Doesn't sound too far off the mark.
Rebuilt AODE (no shop is going to drop in a unknown condition trans)-$1500 minimum
Adapter-$600
Trans controller-$500
Driveshaft mods-$500
Shift linkage-$
Cross member mods-$
Some wiring-$
May require exhaust mods-$
Re-gear axles to allow the overdrive trans to work efficiently-$$$
All the labor required to do the above-$$$
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline   Reply With Quote
Old 06/06/19, 10:55 AM   #6
BanditBronco
BanditBronco's Avatar
Bingo!
Mesa, AZ
I am thinking the same as viperwolf, I don't think it is that far off for So-Cal. Its not just a quick R&R without 10 unforeseen issues. Plus I would imagine you want it to work when they are finished with it. For AOD that means TV cable adjustment, routing, brackets, etc.
351W, 4R70W, Atlas 2, 3.5 inch lift 1 inch body lift, full cage, suspension seats, discs, 37 12.50's, full widths, nics, nacs
BanditBronco is offline   Reply With Quote
Old 06/06/19, 11:57 AM   #7
Rumcustom
Newbie
NW PA
And body lift, yes?
Rumcustom is offline   Reply With Quote
Old 06/06/19, 12:06 PM   #8
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
An AODE would not be my first choice anyway. I would look into maybe a 4R70W instead.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right - Chromo axles, 9"/Grizzly locker - Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline   Reply With Quote
Old 06/06/19, 01:33 PM   #9
mustanggarage
mustanggarage's Avatar
Atlantic, Iowa
you will want a 90 or earlier AOD which is all mechanical, no computer required.
new torque convertor
the adapter for the aod runs about 600.00
you will need to shorten the rear drive line and the front will need to be longer by about an inch and a half.
the transmission is a bit wider so some exhaust modification will be necessary. the shift linkage should still work ok. but will need adjusting and possibly lengthening
you will need a lokar t-v cable.
if you have a j shift dana 20 you will have to twin stick it.
you will need a new flexplate that is 164 tooth and 28 oz imbalance, and a new starter to match.
so there are lots of things to do. it is not all that hard to do, if you have the desire. I put one in a 67 mustang. a lot of the same changes are required. but it does take time and if you don't want to do the work yourself, you are going to have to pay for it. and if the place you are going has not done it several times before, it is going to take them time to research it and figure out all the little tips and tricks that go into this kind of conversion.
yeah that's a lot of money, but there is more to it than simply swapping transmissions.
My build. Tetanus, AKA the mail order Bronco build http://classicbroncos.com/forums/sho...d.php?t=289385
mustanggarage is offline   Reply With Quote
Old 06/06/19, 02:44 PM   #10
StnePny
Santa Monica
2nd on Viperwolf...
When I/we were doing them... we only use '90 - '93 AOD's ...( NEVER an E do to the Controller)...
Our Kit for EVERTHING (DID Not include Labor) was $3500. = Rebuilt Trans with Wide Ratio Gear set, AA Adapter. Modified Cross Member, Trans Cooler, Torque Convertor, Flex Plate, etc,....
StnePny is offline   Reply With Quote
Old 06/06/19, 03:08 PM   #11
Adapt and overcome
Maricopa, AZ
Skip the antique of an AOD, I would prefer a C4.
But if you want an overdrive the 4R70W is a better choice. It has the updates the AODs crave, and has many that the AOD just can't have.
You do NOT want an early AOD EVER! Prior to '87 there was an oiling issue. The planetary gears were starved of oil and self destruct. They work right up until they are opened up and you find the gears are junk.
Old 06/06/19, 03:58 PM   #12
mustanggarage
Atlantic, Iowa
I agree the 4r70w is a better choice than. An aod but I still say if you are going to use an aod an 88-90 will be a cheaper option. It has the upgraded internals so it is as good inside as the later aode but is all mechanical and does not require a trans controller. That does not make it the best option for sure but it is a the best option for using an aod in a carbureted vehicle. I would never consider using an aode because if you are going to all the expense of getting a trans controller and making it work you may as well get a 4r70w.
Old 06/06/19, 05:41 PM   #13
Adapt and overcome
Maricopa, AZ
The AOD-E is just an oddball. same gearing as the AOD but with electronic control.
The single biggest upgrade of going electronic is the selectable lockup convertor. The AOD has no lock in the first two gears and cannot unlock in OD. Third gear is a strange partial lock with a split input to the planetary from both the convertor and direct. The wider ratios, lower first, and slightly less overdrive are the icing on the cake going to the 4R70W.
Old 06/07/19, 06:45 AM   #14
la hi
la hi's Avatar
I put a 700r4 in my 66 behind the 351w . A known quality rebuilder in farmington, and my builder installed it out the door for $2,600. Adapters front and back, shiftier cable, tv cable connected to the Sniper, and everything. No computer needed.
I have a 700r4 in my 57 chevy truck behind a 454BB which always worked great.
La Hi Pagosa Springs/Golden, CO
66 U14 born in January (was junk), now improved
57 chevy truck, 454 + other improvements
la hi is offline   Reply With Quote
Old 06/07/19, 01:13 PM   #15
rpmgarage22
rpmgarage22's Avatar
Builder of all things controversial and a few things remarkable.
Clinton TN. Can tow.
Although technically correct with "no computer", you still need a switch and signal for the converter to lock-up in O/D... Don't need that for the AOD.
Late AOD is a great transmission, when setup correctly. It will take most of the good stuff from the 4R70 and transfer more power than you need for a street rig any day. No controllers, no computers, no trigger wire. Just a basic understanding of setting the kickdown pressure. Shifts smooth as butter, too.
You already have to take it apart to adapt to the Dana 20, so the rebuild is already required.
Mike
(423) 309-9584
rpmgarage22@gmail.com
IG rpmgarage22
1975 Wagon (build to come)
1971 Halfcab- MACK the Halfcab: https://classicbroncos.com/forums/sh...d.php?t=299711
rpmgarage22 is offline   Reply With Quote
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.34361 seconds with 65 queries
