Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 06/22/19, 10:31 PM   #1
bronco t
bronco t's Avatar
Which way is up around here?
Encinitas, CA
Pre 1969 Hardtop Help
Can someone post a pic of their pre 1969 hardtop latch and striker plate.
I am installing a pre 69 hardtop on my 77 and the striker plate parts from my old 77 hardtop are not fitting correctly. I looked on the venders websites and they only list a 69-77 striker plate and nothing for the pre 69 hardtop?
Any help would be appreciated.
1977, cut, 302 2bbl, C4, D20, D44, 3.5 lift, BFG K02 33-12.50, ProtoFab, Bestop.
Aging is where you become the person you should have always been. - David Bowe
bronco t is offline   Reply With Quote
Old 06/23/19, 05:25 AM   #2
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
Confused. Are you installing early doors?
Hard top has nothing to do with the strikers. Just a different bolt pattern to the windshield.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
Why do people keep expecting "normal" from me?
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline   Reply With Quote
Old 06/23/19, 09:07 AM   #3
Scoop
Bronco Influencer
Scoop's Avatar
DS, TX & Cuchara, CO
I think heís talking about the striker plates on the lift gate.
~v~ 72 Pattina Bronco, 74 Ranger, 76 Trail Rig/Crawler, 78 Custom 410M, 84 Custom Big Six
Scoop is online now   Reply With Quote
Old 06/23/19, 12:29 PM   #4
bronco t
bronco t's Avatar
Encinitas, CA
Yes, I am talking about the liftgate latch striker (or whatever it is called).
I found the ones listed below at most of the vendors websites but they are listed 69-77 and they do not list a pre 66-68 version. So, I am wondering if the 66-68 are different?
The parts from my 77 hardtop are not lining up with the latch pin and there is not enough adjustment left, so I am thinking I either have a misaligned top or the wrong latch striker plates.
https://www.wildhorses4x4.com/produc...Liftgate_Parts
I guess the best way to resolve this would be if someone has both versions and could compare them.
Thank You
Dale
Old 06/23/19, 03:15 PM   #5
Fireball05
Fireball05's Avatar
Central PA
I have this photo on my phone. Not sure itís close enough to tell you what you need. Mine is a 68.
'76 LUBER mostly stock - 2.5" Deaver lift - 30" BFGs - D44/9" 4.11 gears - 302/2bbl - D20 - 3 on the tree
"Piece by Piece" Build Thread in progress
Fireball05 is offline   Reply With Quote
Old 06/23/19, 04:36 PM   #6
bronco t
bronco t's Avatar
Encinitas, CA
That is the pic angle I am looking for but is your top a pre 69? It looks like my 77 with the square corner liftgate gaskets / seals.
Old 06/23/19, 05:34 PM   #7
Fireball05
Fireball05's Avatar
Central PA
My truck is a 68. A u15 vin with bulkhead and bench seat as per Marti report. I canít confirm itís history so I guess thereís a chance this isnít the original top?
Old 06/25/19, 01:41 PM   #8
bronco t
bronco t's Avatar
Encinitas, CA
Thank you for the pics! The striker and trim plate look the same as my 77.
Off to cobble ville I go!
Old 06/25/19, 05:01 PM   #9
DirtDonk's Avatar
San Jose, CA
Interesting comment. The '77 should have the curved seals. The early had the squared-off upper corners for the lift gate seal, and the later ones had the curved seal area.
Is that what you meant? Or are you saying the top on your '77 had the square seal?
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
DirtDonk is offline   Reply With Quote
Old 06/26/19, 05:42 AM   #10
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Nice Ride....
Good luck bronco t....
sprdv1 is offline   Reply With Quote
Old 06/27/19, 08:03 PM   #11
bronco t
bronco t's Avatar
Encinitas, CA
I am okay with the two different seals, as I have both. The problem is that the 68 top I have came without striker plates so I transferred them from the 77 and I cannot get enough adjustment out of them to get the latch pins to align.
I don't know if the two striker plates below come from the same manufacturer but one vendor shows a year range while the other doesn't, and this leads me to believe that there must be some differences (if any) between the two eras???
https://www.tomsbroncoparts.com/prod...striker-plates
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.43728 seconds with 63 queries
