Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 06/24/19, 01:01 PM   #1
bronconut1
Aftermarket c4 transmission dipstick tube
Who makes the best one with no leaks
bronconut1 is online now   Reply With Quote
Old 06/24/19, 01:43 PM   #2
jedblake
jedblake's Avatar
66 Roadster
Boulder City, NV
Lokar makes a "pan fill" one that has a flexible neck and the 90* insert is a hard pipe. Others available from many vendors with the "car-style" where the tube is inserted into the trans.
I just replaced my original pan with a aluminum deep pan. However, because of the pan's larger body my original dipstick (specifically at the 90* bend) interfered with my exhaust pipe. I fixed the problem by taking my original dipstick to a local pipe-supply house and they shortened my original tube and soldered on a new threaded fitting. No leaks here. The threaded dip stick fitting is a common size and available from many suppliers.
66 U13, Dana 44, C4, J-Shift, 5.0 347
jedblake is offline   Reply With Quote
Old 06/24/19, 02:04 PM   #3
NYLES
NYLES's Avatar
YOU WANNA WHAT?
FREE RUN, MS
Wildhorses...................
'69, 306 EFI'ed, ZF, DANA 44, 4 WHEEL DISC'S, ASTROBOOST, 3.5"SUSPENSION LIFT, 2"BODY LIFT, GLASS BODY, 37" ON MRW, 5.13's GRZZ/GRIZZ , MOSER, STONE CRUSHER, POWER STEERING, BAILIE BILT, DURABACK, RJM
NYLES is offline   Reply With Quote
Old 06/24/19, 02:51 PM   #4
76YETI
76YETI's Avatar
KC METRO
DITTO^^^^^
https://www.wildhorses4x4.com/produc...c_Transmission
76 Ranger U151, 33"BFG KO2 on Eagle 058s 15x10, 95 5.0 HO Motor, C4, 1" BL, New Stock Suspension. Fabbed rear tire carrier/bumper. Corbeau XRS Seats.
76YETI is offline   Reply With Quote
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.30125 seconds with 61 queries
