Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 10/05/12, 04:27 PM   #1
broke_okie
broke_okie's Avatar
300 C.I. inline 6 install?
I want to install a 300 c.i. inline 6 in my EB . Has anyone done this before? And if so what does this entail? Pics and build threads welcome.
broke_okie is offline
Old 10/05/12, 05:46 PM   #2
Scoop
Have Bronco, Will Travel
Scoop's Avatar
Cuchara, CO
It's been done. Very tight fit but makes for a great engine in an EB.
~v~ 72 Pattina Bronco, 74 Ranger, 76 Trail Rig/Crawler, 78 Custom 410M
Scoop is offline
Old 10/05/12, 06:14 PM   #3
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Might do a search theres a couple of guys running them and some threads. Mostly requires front crossmemeber modifications. I wish it was a better fit in a bronco as i do like the 300.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 10/05/12, 07:10 PM   #4
Revelation
Revelation's Avatar
Got Stainless?
Kissimmee, Florida
It is a fun mod, Be prepared to do some major modifications. I run one in mine and love it, BUT, I built my Bronco around the 300/NP435 combo. Major Mods will include.
Motor crossmember
Trans crossmember
core support
Possible firewall mods
Clutch linkage
The motor has to be moved toward the rear no less than 3 inches, and that barely gives clearance of 1/2 inch from the fan and the radiator with the radiator moved a little forward. you could mod the core support to move the radiator forward to the max.
When the motor is moved to the rear the intake interferes with the firewall unless you center the motor, otherwise you will have to mod the firewall.
The trans crossmember will need to be moved back also to accommodate moving the motor backward.
If you do the swap you will fully enjoy the end product, Being able to wheel all day at idle while the v-8's are all wound up.
You can check my build thread for more info. http://classicbroncos.com/forums/sho...d.php?t=155542
(Get some popcorn, boiled peanuts, a beer or 12 and enjoy the read)
Revelation is offline
Old 10/05/12, 07:23 PM   #5
bmbm
300 in Bronco
A member on here, Revelation, did this and the swap is shown in a past Bronco Driver magazine. He had links to that article on here somewhere.
1966 Bronco uncut, 2.5" SL, 1" BL, 250 six, DSII, NV3550, front disc, 4 turn power steering, twin stick D20, D30, 30x9.50x15
bmbm is offline
Old 10/05/12, 07:50 PM   #6
Revelation
Revelation's Avatar
Got Stainless?
Kissimmee, Florida
Broke_Okie,
Here is the link to your thread back in 2011 on the same subject,
http://classicbroncos.com/forums/sho...d.php?t=188565
Here is the swap from the Bronco Driver.
Thread Tools
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.48965 seconds with 65 queries
