Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 01/21/15, 01:59 PM   #1
redwards69
redwards69's Avatar
Double Oak, TX
Rick's 69 Build
Just picked her up a couple weeks ago. 1969 U15. Tub and sheet metal pretty solid, no major rust in any typical area. Some slight bubbling on lower tailgate and right front fender. Has original 302, but was rebuilt and modded in early 90's with a different cam (still mild), Edelbrock intake and Holley 650. Has original 3-speed changed to floor shift and original Dana 20 T-Shift.
Front steering linkage has been hacked up by PO, so it all needs replacing. Will probably replace existing lift kit as well, think it's 2.5" but quite old. Still has what looks to be factory springs in rear with blocks under them.
It has been upgraded with a 76 Dana 44 with discs up front, original 9" small bearing in rear with drums. Going to replace brakes all the way around along with brake lines and upgrade to power brakes. Need to upgrade to power steering as well.
Don't really care for the bumpers either, so those will go eventually.
Over all a nice rig and I'm looking forward to getting her done!
Click image for larger version
ID:	356279   Click image for larger version
ID:	356280   Click image for larger version
ID:	356281   Click image for larger version
Name:	Front Linkage.jpg
ID:	356283   Click image for larger version
1969 U15 302 - SOLD
redwards69 is offline   Reply With Quote
Old 01/21/15, 02:03 PM   #2
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
Congrats, looks like a nice Bronco but please do not drive it with that steering.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right - Chromo axles, 9"/Grizzly locker - Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline   Reply With Quote
Old 01/21/15, 02:05 PM   #3
Bferrari
Bferrari's Avatar
Nipomo, CA
Those bumpers would make great air tanks for on board air!! Good luck with the build.
Bferrari is offline   Reply With Quote
Old 01/21/15, 02:19 PM   #4
Bukin 67
Bronco Abuser
Bukin 67's Avatar
I ♥ being stroked
Southern California
You found a good one - Good luck with the build!
"The Bukin'eer" 67 Sport. All unoriginal
Bukin 67 is offline   Reply With Quote
Old 01/21/15, 02:27 PM   #5
FRANKO289
Bronco enthusiast
FRANKO289's Avatar
71 on 39.5s
PALM BEACH FL
the rear tire carrier looks like from a 80s cheby blazer ...
very rare item and very desirable w. the military blazer and suburban guys !!
FRANKO289 is offline   Reply With Quote
Old 01/21/15, 03:13 PM   #6
NGABronco
NGABronco's Avatar
Looks like a nice rig!! Congrats!!!
The PO probably had problems fittin the steering of a 69' up to the 76' D44.
The 44 disc knuckles are different from non disc. Check with WH on the steering parts.
Good Luck!! And have fun!!!
It's only money, I hope the government sends me more tomorrow!!!
NGABronco is offline   Reply With Quote
Old 01/21/15, 04:28 PM   #7
redwards69
redwards69's Avatar
Double Oak, TX
No worries, not a chance! It's all coming off and sending both front and rear housings out for new seals/bearings/gears, etc.
Ha! Had not thought of that. Let me know if you know of anyone interested.
Interesting. If anyone knows of someone that needs it, let me know.
Thanks for the comments guys. I've already disassembled the rear drums and will be removing all the steering linkage, suspension and axle housings this weekend.
1969 U15 302 - SOLD
Old 01/22/15, 10:04 AM   #8
PaveBronco
PaveBronco's Avatar
Fort Worth, TX
looks like a good find, once you get rid of the PO's crap. Engine looks good. Also looks like it had the RT side tire carrier latch at once time. keep the updates coming, be interesting to see what other PO gem's you find.
PaveBronco is offline   Reply With Quote
Old 01/22/15, 11:19 AM   #9
redwards69
redwards69's Avatar
Double Oak, TX
Axle housings and steering linkages all coming out this weekend. While the housings are off getting rebuilt, will replace all the brake lines and add power brakes, then new steering linkages when axles return.
One thing that I have noticed is no PO has ever replaced a wire in this thing. They've added wires to add items or replace a bad connection, but they didn't necessarily remove the old wiring. There are wires everywhere! I'll definitely need to put in a Centech/Painless harness before long.
1969 U15 302 - SOLD
Old 01/22/15, 11:48 AM   #10
Sporto
Sporto's Avatar
Can do easy...
Fountain Inn, SC
I like the soft doors. I think the PO had the snaps on the windshield channel and front lower section added. There are small parts that hold these in place that are much more aesthetically pleasing than those. However they look to be in decent shape.
Great find, keep us updated on your build!
Rich
If at first you don't succeed...Then you're not Chuck Norris...
Sporto is offline   Reply With Quote
Old 01/24/15, 06:15 PM   #11
redwards69
redwards69's Avatar
Double Oak, TX
Started removing the front axle housing today. Got front drive shaft off, brake line off, shocks disconnected, and radius arms loosened. The ball joint holding the drag link to the pitman arm was broken, so the nut just turned. Had to remove the entire pitman arm. That took a bit of effort, but it finally came off.
One thing I did notice, was the were no nuts on any of the body mount bolts . The previous owner was driving it this way, crazy!!
1969 U15 302 - SOLD
Old 01/25/15, 09:32 AM   #12
Bferrari
Bferrari's Avatar
Nipomo, CA
Wow! Better check the entire rig with a fine tooth comb! Glad to see your sorting it all out, keep it up!
Old 01/30/15, 05:57 PM   #13
redwards69
redwards69's Avatar
Double Oak, TX
Ordered a complete power brake package today, booster, hard lines, flex stainless steel lines, proportioning valve, almost everything needed to make the braking system new. Looking forward to putting things on this rig vs taking them off!
1969 U15 302 - SOLD
Old 01/30/15, 06:05 PM   #14
savage
Bronco Nut
savage's Avatar
god,family,country,4x4
Renton,wa
The washer is the nut for the stock body mount. Their are threads inside the washer.
TAZ-74 bronco,302,c-4,dana20 and 3.5inch lift WILDHORSES
savage is online now   Reply With Quote
Old 01/31/15, 08:15 AM   #15
redwards69
redwards69's Avatar
Double Oak, TX
Well that's reassuring. Thanks savage.
1969 U15 302 - SOLD
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.52765 seconds with 71 queries
