Hinmaton
- Oct 17, 2017
- 590
I have an ididit tilt column from WH4x4 in my 74. I recently replaced the Grant steering wheel with an original SW and horn ring that is in decent shape. The horn mechanism was not functional when I purchased the project, but I’d really like to get it hooked up so I can register the vehicle legitimately.
I am confused how the horn switch is intended to function and will it work with combining a modern tilt column with an original steering wheel.
I have checked the wiring at the column and there is no voltage at the horn stud/button thing.
Should there be with ignition on?
I have bench tested the horn, and it works fine.
I checked continuity from the horn stud down passed the column wiring connection- B/R wire. No signal, but the connection is good.
I checked the wiring diagram and see that a Y wire brings signal to the horn switch (which I did not find) and then the B/R wire goes from switch to horn relay (which I do not know where to look for) from which a Y/G wire runs from dash to horn. I was able to peel away some of the harness sheath in the engine bay and followed from the horn to a penetration in the far right corner of the firewall.
I could peel away the sheath under the dash, but it would more helpful if I knew the area of the dash that that wire pokes back out (at the relay).
Can anyone provide any feedback or insights?
This is the wiring diagram I was using, note that it’s for 73-74 but it shows wiring for 73 only for the horn and then mentions that 74 horn wiring is the same as 75...
