I need some help. My rig has been running hot for years. Currently I get up to 225 on the hiway on nice 75 degree days. I also tend to run hot on the trails and I really have to manage the temp on the trails by opening hood when stopped. Before anyone responds with the standard "are you running a fan shroud," here are the things I have done over the years (and please note these items were added because I was running hot; I did not begin to run hot because I added them):
1) Flow Kooler Hi flow water pump. I have since replaced this with a stock replacement due to my serpentine set-up.
2) Multiple radiators- stock, 4 core and 3 different Champion radiators
3) Stock mechanical fan (ran fine on hiway but not enough air while crawling)
4) so I added Electric Derale Fan as a result of advice from this forum (unable to run elec fan as supplemental pusher due to stock hood latch in front of rad)
5) Ran electric fan with and without shroud (currently running metal shroud)
6) Everything from straight water to 50/50 with water wetter
7) Various thermostats set-up ranging from no thermostat to 160-195 (such as the Shaw Hi Flow ones)
The only thing I have not done yet is to add the under the hood. Although, that may be a good thing to add, I just cannot figure out why some big cube, big HP engines, have no issues cooling with bone stock radiators.
Rig specs as follows:
351 with BC ceramic shortys and 2-1 3" exhaust, 4R70W, 4.56 and 35s, 2 inch BL
Engine specs:
1) stock non-roller from 1990 F250
2) Heads ported (gaskets were triple checked by multiple people to ensure they were installed correctly)
3) off road Comp Cam
4) Edlebrock intake
5) Running digital ECT gauge from EFI unit and also analog Autometer gauge
6) MSD atomic EFI. EFI parameters:
- I added mechanical adv everywhere from 2 to 15 degrees BTDC
- Added additional vacuum adv (on top of mech adv) from 0 to 15 degrees
- Have set total timing everywhere from 2000 to 3500
- Air fuel mix from 12.5 to 14.8. I have chosen different ratios used for all three positions (idle, cruise, and WOT).
So my questions are:
1) Where is your timing set (mech and vacuum?
2) What is your total timing (mine is ?
3) What RPM does your timing begin (mine is at 1100 right now)?
4) What air fuel ratio do you run?
5) Finally (and I am grasping at straws here), I have a theory that the elec fan (in puller mode) is restricting the airflow at hiway speeds. Since my fan only pulls 2400 cfm, maybe the fan is actually limiting the thousands of additional cfm that would otherwise be flowing through the rad at hiway speeds. Again, I am grasping for anything here but wondering if anybody else had a thought on that theory.
Engine specs:
4) Edlebrock intake
