Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 03/06/20, 03:58 PM   #1
migs
migs's Avatar
NH
migs Bronco Barn - a chronicle of what's happening at the new place
Welcome to my Bronco Barn.
So, after all the enjoyment I've had creating and keeping up with the individual build threads, I thought it might be fun and entertaining to chronicle the various projects that I'm working on in here from time to time... be it my own builds, small projects, projects for friends, or a new part in creation...maybe even a few non Bronco related things now and then. I have a habit of jumping around from project to project so this will at least help me keep track of what I've been working on and how much I've been slacking off...
Why call it a Bronco Barn?... It may not be a true old fashioned barn and more of a modern garage if you will, but it is shaped like a barn and built into a hill side with multiple levels, plus there are chickens and tractors hanging around...and of course it's typically filled with at least a few Broncos...
Someday I would like to refinish it so it looks more like a real barn on the outside.
This endeavor started a couple of years ago when I had the opportunity to move to this new place, and it has pretty much taken all this while to really get things set up to a point where I can start to feel productive. I still have more to do but most of the important stuff has been squared away.
Hopefully good things to come here on out...and lots of Bronco pictures!
Well let's start off with some views of the place along with some of the tenants and a few of the visitors that have stopped by...
Click image for larger version
ID:	495898   Click image for larger version
ID:	495899   Click image for larger version
ID:	495900   Click image for larger version
ID:	495902   Click image for larger version
ID:	495903   Click image for larger version
ID:	495904   Click image for larger version
ID:	495906   Click image for larger version
ID:	495907   Click image for larger version
ID:	495908   Click image for larger version
migs is offline   Reply With Quote
Old 03/06/20, 03:59 PM   #2
migs
migs's Avatar
NH
This post contains links to stuff...
My 1970 uncut daily driver/rock crawler build
My 1966 U13 roadster project
My 1967 U14 half cab project
Old 03/06/20, 04:32 PM   #3
migs
migs's Avatar
NH
One of the first outsiders to come in early for some help (amidst the shuffling around of everything in the shop) was fatboy's yellow Bronco. see it's build thread here.
the goal was/is to just get it road worthy so it can be used while his other project is underway. among many other issues, it was in desperate need of front suspension bushings...
It's currently still here and probably a little behind schedule but some progress has been made...
ID:	495912   Click image for larger version
ID:	495913   Click image for larger version
ID:	495914   Click image for larger version
ID:	495916   Click image for larger version
ID:	495917   Click image for larger version
ID:	495918   Click image for larger version
ID:	495920   Click image for larger version
ID:	495921   Click image for larger version
ID:	495922   Click image for larger version
Old 03/06/20, 04:41 PM   #4
migs
migs's Avatar
NH
And tasker has been keeping me busy with rear axle projects
First he brings me one to rehab after finding out that they don't work too well without gear oil...
ID:	495924   Click image for larger version
ID:	495925   Click image for larger version
ID:	495926   Click image for larger version
ID:	495928   Click image for larger version
ID:	495929   Click image for larger version
ID:	495930   Click image for larger version
Old 03/06/20, 04:42 PM   #5
NGABronco
NGABronco's Avatar
HaHa!!! Nice "Barn"!!!! I think I know some of those rigs??
Good luck with it all!!!
It's only money, I hope the government sends me more tomorrow!!!
NGABronco is offline   Reply With Quote
Old 03/06/20, 04:44 PM   #6
migs
migs's Avatar
NH
and then axle project number two after he discovered that water is no substitute for gear oil...
ID:	495932   Click image for larger version
ID:	495933   Click image for larger version
Old 03/06/20, 04:48 PM   #7
Juiceman
Juiceman's Avatar
North Shore, MA
dang Migs! You have been busy.
Juiceman is offline   Reply With Quote
Old 03/06/20, 04:49 PM   #8
migs
migs's Avatar
NH
all new gears and bearings, a new carrier as well as a beefy new housing. the axle shafts were pitted where the seal rides but I was able to turn a touch off in the lathe to smooth it out. added a drain plug to the housing and welded on some shock mounts then cleaned it all up, painted it and put it together.
ID:	495935   Click image for larger version
ID:	495936   Click image for larger version
ID:	495937   Click image for larger version
ID:	495939   Click image for larger version
ID:	495940   Click image for larger version
ID:	495941   Click image for larger version
Old 03/06/20, 04:51 PM   #9
migs
migs's Avatar
NH
the finished product. also gave it a touch of his favorite color
ID:	495944   Click image for larger version
ID:	495945   Click image for larger version
ID:	495946   Click image for larger version
Old 03/06/20, 04:57 PM   #10
migs
migs's Avatar
NH
thanks Ben, you should bring one of yours up for a picture out front too sometime
it just looks that way... mostly been shuffling everything around
Old 03/06/20, 05:42 PM   #11
Bonefizz
Santa Clarita, CA
This is my Disneyland.
Bonefizz is offline   Reply With Quote
Old 03/07/20, 07:57 AM   #12
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
mine too! as nice as the work is, it pales in comparison to what a smart, meticulous great guy Migs is....thankful that we met AND he is also member of EONES....(Expedition owners North East States)
He has saved me a couple times now!
ID:	495965   Click image for larger version
tasker is offline   Reply With Quote
Old 03/08/20, 06:48 PM   #13
fatboy
Glad to be here.
fatboy's Avatar
Bad decisions make for good stories.
Coastal NH
THIS, he has saved us all a couple of times. He is a great guy and a hell of a fabricator!
Life's a Journey Not a Guided Tour.
Good judgment comes from experience. Experience comes from poor judgment.
The Mutt
Village Idiot Build
fatboy is offline   Reply With Quote
Old 03/09/20, 03:56 AM   #14
romegadave
romegadave's Avatar
rome ga
Cool things have happened at the Bronco Barn
Been warped by the rain driven by the snow...
romegadave is offline   Reply With Quote
Old 03/09/20, 05:37 AM   #15
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Love the view for sure. And look forward to the build
sprdv1 is offline   Reply With Quote
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.52532 seconds with 69 queries
