Now i need to connect the battery wire to the starter and also need to figure out some electrical items.
-It seems there are battery wires going directly from the battery to the starter and alternator and there are not any fuses in the mix?
-The brown and green wire shown goes to the ignition side of the starter. Might end up cutting this wire and put the cut end on the starter so it's separate from the main harness for now?
-There is also a wire coming from the Ford Racing power distribution box (black box with red wire in the center right of the picture) that is saying it needs a direct connection to the battery. The wire on that is pretty short, not sure where people mount this box, it is recommending the glovebox?
Guess i need to do some research before proceeding
