I know for a fact they were found in, as far as Broncos from 78' to 80' when I was hunting for them. But I found more 208s in 80' Broncos, that may be different for trucks.
Heres some internet stats I found.
NP 205
Type: Gear-driven, cast-iron
Low-range ratio: 1.98:1
Weight (lb.): 138
Lubricant: 80- to 90-weight
Length (in.): 13.0 (GM); 16.0 (IH)
Width (in.): 18.0
Height (in.): 12.0
Used by: 1971-1980 Broncos, Blazers, and Ramchargers (and corresponding full-size pickups); the NP 205 is still used on
heavy Dodges. Some Dodge and IH models were longer, "divorce-mounted'' versions. The NP 205 has left- or right-side front outputs and a center rear output. Caution is advised: there were many varieties in NP 205 shaft splines and so forth. A PTO plate can be found on the left side of the 'case.
The "Ford" NP205 transfer case uses the 6 bolt circular bolt pattern . It has a left hand drop (driver's side). It is supplied with a 31 spline female input.
Rear Output
Is a 32 spline shaft and will accept a 1310, 1330, or 1350 u-joint yoke, and the 1310 CV yoke.
Front Output
Is customarily a 32 spline shaft, same as the rear with interchangeable yokes.
http://www.high-impact.net/transmission_and_gear/Tcase_NP205.htm
