- Aug 13, 2021
- 290
I’m going to be updating my radiator and coolant lines…
My ‘66 has the original radiator in it I’m pretty sure… has the cap off to the side and looks like photos of the 66’s I’ve seen. It still works, but I just don’t trust it as my temps can hit 210 idling on a hot day… doesn’t help I don’t have a fan shroud. I’m running a C4 auto trans, mechanical fan, no shroud, and a 302. I’ll be adding a shroud
, came without one…
I’ve been reading threads on here and seems to be some debate about aluminum 3 core vs 4 core… that the extra thickness of the 4 core actually can harm air flow due to tight space between all elements.
Also should I worry about using a 1/2” fan spacer? Stock is 3/4”… has anyone had clearance issues issues with their belts?
Also curious does it cause problems to use a stock water pump with a 4 core radiator?
Any other concerns or things I should consider? Just trying to anticipate ripple effects and make wise decisions before making the plunge.
