bradhopkins15
- Apr 4, 2012
- 3
9I have almost every piece needed to build this 408 stroker minus the oil pan and headers. I was going to put this engine in my 1967 Mustang but something has come up and I need the money. I looked online at JEGS and SUMMIT yesterday to price out all the parts. If you bought all these parts yourself, buy a 351w block and pay to have the machine work done, you would pay over $9000 with tax. All these parts are new. You are saving $3000 dollars. All you have to do is assemble. With these parts the engine will make an estimated 475 horsepower and 525 torque.
Summarized parts list:
Machined 351w block, AFR aluminum heads, comp cam, edelbrock performer rpm airgap intake, holley 750 carb, forged scat rods, forged probe pistons, cast scat crank, melling Oil pump, pro street balancer, edelbrock fuel pump, Summit starter, comp aluminum roller rockers, comp pushrods, clevite bearings, felpro gaskets, MSD ignition control, distributor, wires, adjustable timing control and coil wire hold down, Mr gasket water neck, edelbrock carb spacer, moroso aluminum valve covers, air cleaner and breathers, comp roller timing set, mahle rings, comp hydraulic roller lifters, ARP studs and bolts, timing cover, water pump, spark plugs, and other misc parts.
Email, text or call bradhopkins15@gmail.com (949) 278-7360.
