- May 28, 2013
- 1,774
Moving along on my 351 build and will stick with the stock two belts and not going serpentine.
I know there are the adapter brackets below to swap things over, but are there other bracket options for the alternator and Delphi pump that wont require the adapters?
Also, any recommendations for decent priced crank and water pump pulleys for the 351?
Thanks and hope all are having a great Labor Day !
351W Power Steering Adapter Bracket, 66-77 Bronco
This adapter bracket will line up the power steering pump in the factory 302 position so that you can retain your power steering pump bracket for use on your 351W. You will probably also want the alternator adapter bracket available below. WARNING : This bracket is designed for the...
www.wildhorses4x4.com
351W Alternator Adapter Bracket, 66-77 Bronco
This adapter bracket will line up the alternator in the factory 302 position so that you can retain your alternator bracket for use on your 351W. You will probably also want the power steering adapter bracket.
