just completed a 331 400hp build w/ a custom cam for the bronco w 4:11 she's pretty torquey I dind't want somthin" to smoke the tires she digs in and goes, my shift points w/ c/4 is 4200 on the down and WOT is 5,200 rpm and for kicks and grins I took it to the local track and she turned high 12,s Kinda the best of both worlds torque and speed. as far as torque when down to 2nd the left front feels like its coming off the ground so I can only figure what a 408 would do. rwhp @ 258 Plus 30 % thats about 370/380 right under 400 so thats where I wanted it , but I know 351, 357 roller stand on and thell just sit and smoke the tires. how much launch you want?? Ive droped the transfer to fix adapter leaks 1 too many times was far as wheeling I don't even put my foot into it it climbs @ idle to 1300 rpm.W a 2100 stall, just my 02, could be my age, the 347 woulda cost the same. I had my reason. if your gona use d/60 1ton stuff c/6 or 4r yes 408 loosing 175hp/ 200 hp. by all means go big. My original plan was a dart blocked 363 @9.5 comp but $ out ways the means. a 408 with 400hp @ 3.5 K should be a blast .
