City:
Bellevue
Price: $ 19500
Price: $ 19500
66 Bronco EFI Project
This was started by a fellow Bronco enthusiast, an engineer who was very meticulous and thorough. He previously completed a EFI set up on a couple other Broncos and started this project but lost interest in completing it.
This will be a great bronco for someone who is looking for a fairly easy project to put together. All you need to do is to add your finishing touch to it.
The body is very solid. All the rust has been cut out and repaired. The body will be sitting on rolling chassis with new body mounts that has a 5.5 lift. All running gear, engine, transmission will already be mounted securely to the frame.
This bronco will include along with the title:
• 66-body that has been sandblasted and primed (it will require some miner body work for dents and dings)
• 66-frame that was sand blasted and painted black
• 89-5.0 HO EFI engine with Mustang wiring harness
• Newly painted long tube headers/sensor for EFI
• Good dual exhaust set up
NP 435 4 speed transmission (gone through by the previous owner)
• New clutch and pressure plate
• New clutch fork boot (Tom’s offroad)
• Dana 44 with 350 gears (gone through by the previous owner)
• New front disc brakes (Ford conversion)
• Dana 20 with twin shift setup (gone through by the previous owner)
• New dana 20 transmission mounts (Tom’s offroad)
• PTO wench (Koenig)
• Both drivelines in great condition
• 9” small bearing rear end 31 spline with drum brakes
• 4 Great looking aluminum ultra slots wheels
• 4 tires 33x12x15 wild county (lots of tread)
• New duff 5.5 Coil Springs
• New Duff 11 leaf Springs
• New polyurethane 1” body mounts (Tom’s offroad)
• 4 Shocks
• Radius arm with new C bushings kit from Duff
• Steering drag link
• Reversed F-150 Power steering 4x4 box (one of the strongest)
• Power Brake booster and master cylinder (painted) Front disc and rear drum proportioning valve
(painted)
• New Aluminum Radiator set up for serpentine
• New 23 gal Rear main tank with EFI return line
• 1973-dash with cluster, knobs, glove box door ashtray, and harness
• Dash pad (needs cover)
• Heater box / motor blower
• Drivers vent box
• Steering column and shaft (newly painted)
• 1973-Windshield frame (glass has crack & rock chips)
• Electric wiper motor / bracket on windshield
• Two new front fenders (primed)
• Hood (primed) great shape with fiberglass scoop, hinges, prop, and hood release
• 66-Tailgate all complete components, ok condition
• Painted front steel bumper with winch and steel cable
• Painted (Black) rear steel bumper
• 66-Grill great condition (primed)
• 1 passenger Door no internals (needs work)
• Front seats are 89 mustang power seats (Photos to come)
• Front and rear flexible fender flares (white) Aeroz Taillight lens and buckets
• Headlight buckets
• E-brake mechanism and cable
• Brake, clutch and gas petal assembly (painted black) • 66-Grill lens
This Bronco is ready to go now! All parts will be packaged up in a crate and loaded inside the body for transport.
I am sure if we have any other small parts that I have forgotten, we will throw it in with the Bronco If you are interested, we are asking 19,500.
Backstory: My buddy and I have been collecting and restoring Broncos as a hobby for the past 5 years or so. This is one of our project Broncos we have been putting together but would prefer to sell at this point so you can make it your own and finish it how you would like.
If you have any questions about this Bronco or other projects, we’re working on, please feel free to reach out to me.
• 4 Shocks
(painted)
• Drivers vent box
• Headlight buckets
