- Jul 31, 2001
- 8,674
I have a Quick 6 Gen 2 in a 6r80 for over a year and am trying to get the NSS to work for finishing tuning. Is Pin 1 (on the 16 pin connector) with the gray wire the source for this connection? All I need is a ground signal when and only when the the 6r80 is in P or N. No voltage, just a ground like it's supposed to have to operate a relay to keep you from accidently starting your engine in gear.
I have tested this wire off of Pin 1 and it does not go to ground when the trans is in P or N either with the key on or off. No voltage either.
What wire coming out of the trans is connected to what wire in the Quick 6 harness that would give me this grd source? I have torn my entire controller harness apart tracing wires but have not pulled the actual connector to the trans off since if I remember correctly you get access to it when the pan is off. Another $120 in fluid costs...
I don't have much hope of USShift ever getting back to me since they have become so busy and don't return calls or emails reliably. Their customer service used to be outstanding. Now it's like they are outstanding in a "no service zone" where emails & phone calls never make it to them.
UPDATE: (I got through after 2 days of calling). Yeah!!
