7/16"-20 cam core thread size.
Madgyver
Bronco Madman
Found this out during assembly.. ran a google search and found out that this is common. 7/16"-20 where stock is 3/8"
Is it always three eights inch on stock engines? Or could it have been a running change from the factory as well?
Is that a flattened copper pipe?
Madgyver
Madgyver
Bronco Madman
All SBF cams that I have came across were all 3/8"
it is a copper tube with a steel bar in it that I drilled and tapped to use as my grounding base.
