- Feb 15, 2017
- 31
Hey Everyone!
Well I started on this forum back in February of 2017 with a 62 4X4 Chevy Suburban. With help and direction from so many including JGO (James Goguen) I was able to sell the Suburban to a fellow forum member (Dough Boykin) and grab a 72 Explorer Sport from BajaFresh75 (Chris) that was going to be rebuilt by Mark Atherton. I am including the link below to that initial thread for your viewing pleasure.
https://classicbroncos.com/forums/showthread.php?t=277237
After the 72 was picked up in Tennessee and shipped to Mark it sat for a while. Mark was extremely busy and although we could not come together on the build he worked with me diligently to either sell it or get it to the next builder. By April 2018 my bronco was on another trailer and being shipped to Mississippi to be built by James Steed. If you do some searching through the forum you will find him popping up every once in a while with nothing but positive comments. He is a full time fire fighter who owns his own shop that works on collisions but specializes in classics, mainly broncos but even has a full Eleanor build in the shop alongside the bronco builds.
I could not be more satisfied with how the build has gone. James and I worked on a very specific build that was well laid out, extremely comprehensive with no corners cut.
Here is a breakdown of what we are working towards...
1972 Ford Bronco Frame-Off Restoration
Disassembly of body including doors and front clip
Removal of body from frame
Body media blasted and rust areas addressed
Doors will receive new glass and vents and replace necessary hardware and rubber
New windshield and windshield gasket
Body work finished and blocked to a finish to be painted
Matching body color bed liner undercoating
Black interior bed liner
The hardtop will be body worked and painted as well (all new glass and rubber)
Body painted with base coat clear coat Grabber Blue
Hardtop, grill and interior dash - Bright White
Sanded and polished
Chassis disassembled and blasted and chassis coated
Front & rear axles are rebuilt with new bearings & seals
Blast and epoxy primer and paint frame
New family roll cage that will fit a hard top
New bright white fiberglass flares
Install new 23 gallon fuel tank, sending unit and fuel lines
New exhaust and headers
3.5 inch suspension soft ride lift (Leaf springs, coil springs, drop bracket for track bar, pitman arm, new pro comp shocks and steering stabilizer)
All suspension bushings will be changed
Blue Print 306 engine
https://blueprintengines.com/collections/ford-crate-engines/products/ford-306-base
FAST EFI system
4r70w transmission rebuilt with overdrive
New Centech wiring harness
Ford 9" rear axle
Dana 44 front axle
New Warn locking hubs
New front power disc brakes & rear drum brakes
New steel brake lines & fuel lines
New E brake system
New poly bushings & mounts throughout
New steering linkage w/steering stabilizer
New extended drive shafts
Power steering conversion
New automatic steering column with shifter
Wood steering wheel
New oil pump, water pump, fuel pump, starter, etc...
New radiator, heater core, & hoses
Vintage Air Conditioning
Refurbished stock gauge cluster & new speedo cable
Amp Power steps
New upper dash pad
New wiper/washer components
15 inch M/T classic wheels with BFG all terrain tires (5)
New chrome bumpers and bumperettes, door handles, headlight rings and other misc. chrome items
Classic chrome bezels Chrome door hinges, chrome handles and cranks
Chrome headlight bezels and chrome rear view mirrors
Sport bronco side markers
Rear swing arm for 5th tire
PREMIUM Seat Kit Front Buckets w/ Fold & Tumble Seat - Black w/Brackets
Aftermarket seatbelt kit installed front and rear for 5
TBP Locking Security Console without Stereo Port, Black
Classic black leather style door inserts
OE Style "Model 4" Radio with SiriusXM, AM/FM, Bluetooth, USB & Ipod/Iphone
USB/Aux Input Extension Cable for Retrosound Stereo
Black Finish 5.25" Dash Speaker with Dual Voice Coils for Stereo Mix
New hardware throughout and weather stripping throughout
New exterior lighting throughout
Misc Missed Items (lighting, belts, screws, bolts, windshield wipers, heater setup, bezels and probably much more)
I never had any fear that James was going where we were not planning on going together or cut any corners. We have shared multiple calls, FaceTime, photos and text over the last 22 months. James was super patient with me especially when it took me almost 2 months to decide between Grabber Blue and Bahama Blue. He even sent me multiple color samples and had me speak directly with other paint specialist until I made my final decision. We are literally in the home stretch and I have my flight secured to go out and see the bronco with my cousin on March 11th before we ship it home. I will start following this up with a ton of photos.
Really hoping to have the bronco with me for the Wild Horses Roundup on April 20th. https://www.wildhorses4x4.com/wh_event_reg
Enjoy the pictures!
AJ
Sanded and polished
FAST EFI system
Ford 9" rear axle
Dana 44 front axle
New E brake system
Wood steering wheel
Amp Power steps
New upper dash pad
Enjoy the pictures!
AJ
