A bit more info
Engine
3/8" Fuel line feed and return $68.00 Hose products
1989 Mustang 5.0 Engine from Mustang with forged pistons (good for forced induction); 69k miles $900.00 Bought locally
80MM Ford Motorsport MAF $300.00
www.kennebell.net
Accufab 70MM Throttle Body and EGR spacer $265.00 JDs performance
BC broncos 1 qt. fuel accumulator and filter $70.00 BC Broncos
BC Broncos Radiator Guard $35.00 BC Broncos
Carter 90gph low pressure fuel pump $82.00 Summit racing
Chip from Kenne Bell for tuning $299.00
www.kennebell.net
Cold air induction with Kenne Bell System, 8" K&N filter $153.00www.kennebell.net
Dual exhaust; Flowmaster mufflers $590.00 Done locally
Extrude honed lower intake $275.00 Bought for $75, extrude honed
Felpro FEL-8548PT-2 graphite head gaskets $40.00 Autozone
Ford 3g 130amp alternator $175.00 NAPA, bought new not reman.
Ford Motorsport 36# injectors $360.00 Ford dealer
Ford Motorsport fuel injection harness - new $225.00 Summit racing
Ford Motorsport O2 sensor harness - new $45.00 Bought locally
Ford Motorsport Relay kit and harness - new $88.00 Summit racing
Ford Motorsport shorty headers, Jethot coated $299.00 Summit racing
Ford Motorsport X3z Cobra Computer $100.00
www.corral.net
Ford Motorsports smog pump elimination pulley $49.00 Ford dealer
Gano Filter solid brass coolant filter $45.00
http://www.catsradiator.com/gano
GTO upper radiator hose $18.00 Autozone
J&S Ultra Safeguard individual cylinder knock control system w/ boost retard
$495.00
http://www.jandssafeguard.com/
Kenne Bell 8psi Supercharger Kit $2,999.00
www.kennebell.net
Kenne Bell bypass kit (keeps air charge cooler) $499.00
www.kennebell.net
Kirban billet aluminum fuel pressure regulator $69.00 JDs performance
Mandrel bent steel lower radiator hose $45.00 Bought from Todd. Z on EBML
MSD 6al ignition with rev limiter and shock mounts $208.00 Summit racing
MSD BlasterSS Ecore coil $36.00 Summit racing
New replacement timing chain from ford $89.00 Done to insure there was no stretch
New replacement timing cover from ford $125.00 Done when motor was purchased
NWMP 21 gallon fuel tank and hoses $413.00 wild horses 4x4
Optima battery $135.00 Napa
Painless Wiring Circuitboss 7-circuit weatherproof auxillary wiring harness with fuses $58.00 Summit racing
Polished Ford Motorsport aluminum valve covers $75.00 Bought from boneyard, polished Romac SFI Certified Aluminum Harmonic Balancer
$259.00 houston performance
Sanden A/C compressor for on board air $75.00 Bought locally
Solid Fan $45.00 bc broncos
Stage 8 locking header bolts $42.00 Bought at summit racing
Taylor Spiro Pro Spark Plug Wires $56.00 Summit racing
Vortech T-rex 50/70 Fuel Pump $239.00 Summit racing
Wild Horses Staggered core 4-core radiator $284.00 wild horses 4x4
Transmission
700r4 to Ford smallblock adapter kit $350.00
http://www.advanceadapters.com
700r4 to Atlas II transfer case adapter $216.00
Add "K" Case (4wd) $50.00
http://www.700r4.com/trans/level
Add 5 pinion planetaries front and rear $175.00
Adjustable TV cable cam for shift adjustment
without changing critical initial and final pressures
with Lokar braided TV cable
$129.00
http://www.bowtieoverdrives.com
B&M 28,000 GVW stacked plate cooler w/ 1/2" NPT fittings $60.00 summit racing
Bowtie Overdrives Level 3 700r4 (600hp/600ft/lbs) - $1,284.00
Chevy TV cable $22.00 Chevy Dealer
Dipstick tube and filler $19.00 Chevy Dealer
Dust cover $20.00 Chevy Dealer
Energy suspension HD polyurethane transmission mount (limits wrap and windup)
$21.00
http://store.summitracing.com/pa
Hughes Transmissions finned pan (adds 3 quarts capacity) $140.00 summit racing
Lokar Aluminum 23" shifter with mushroom shifter knob $195.00 summit racing
Magnefine transmission filter with bypass $30.00
www.700r4.com
Metal lines for tranny $21.00 NAPA
Midwest Hybrid Torque Converter; 2.7:1 STR, 2400 Stall, Lockup $674.00 HPA associates
Painless fan harness for spal fan $60.00
http://store.summitracing.com/de
target=eproduct.asp&N=120+400
Pushlock fittings and lines for tranny $65.00 Hose products
Spal 8" fan mounted on cooler $88.00 Baker precision
Spicer stick mounted shiftswitch for manual lockup. $65.00 Six States
Transfer Case
1310CV yokes front and rear $0.00
32 spline front output shaft upgrade $181.00
http://www.advanceadapters.com 4.3:1 ratio Atlas II $2,019.00
Ford VSS sensor $85.00 Ford dealer
Speedometer cable $42.00 Local speedo company
Tom woods long-travel drivelines; 1310 CV, sealed slipyoke $580.00
http://www.4xshaft.com/
Twin stick shifters $0.00
Billet aluminum burp/vent tank $85.00 Summit Racing
Front Axle
5.13 Gears $175.00
http://www.ring-pinion.com/
5-760 ujoints $45.00 Six states
ARB air compressor $199.00 Complete Offroad
ARB Air Locker $650.00
Bearings for front rotors $46.00 NAPA
Braided stainless lines $85.00 Baker Precision
Brute Force Pads $50.00 Pep Boys
Brute Force rotors $120.00 Pep Boys
Custom cut tracbar $75.00 Self
Dana 44 High Pinion Full Width $850.00 Bought Locally
Energy suspension front bushing set $60.00 4 wheel parts wholesalers
Lincoln upgraded calipers $85.00 Napa auto parts
Pushlock hose for ARB with BSP fittings $42.00 Hose Products
R&P setup, ARB install $200.00 MS conception motorsports
Warn Premium Hubs $80.00 Six states
Rear Axle
5.13 Gears $210.00 Complete Offroad
add 3/8" thick tubing $75.00 Moser Engineering
add back brace $75.00 Moser Engineering
add drain plug, flush with bottom $35.00 Moser Engineering
add spring perches $20.00 Moser Engineering
Bearing and shim kit for rear end $125.00 Randys ring and pinion
Brute Force pads $49.00 Pep Boys
Daytona iron pinion bearing support w/ bearings $160.00 Moser Engineering
Detroit Locker $399.00 Complete Offroad
Disks new and machining to fit $88.00 Napa and local machine shop
Fab up HD rear mount for rear axle; 1/4" thick steel, boxed in $45.00 Self
Full Width Housing by Moser $290.00 Moser Engineering
GM calipers $68.00 Napa
HRW/Moser 3rd member (case) - Nodular Iron $475.00 Moser Engineering
Rear end; r&p setup and detroit install $200.00 MS Conception Motorsports
Warn 31 spline full floater kit w/ Warn premium hubs $739.00 4 wheel parts wholesalers
Warn disk brake brackets $85.00 Bought used
Rear axle done in POR-15 $0.00 Keystone autobody supply
Warn solid drive flanges $125.00 4 wheel parts wholesalers
Suspension
35" Goodyear MTR tires with Eagle 15X8" Rims;
with road hazard warranty
$1,093.00 Discount tire
BC Broncos offset radius arm bushings $35.00 BC Broncos
Bilstien Remote Reservoir 7100 Shocks; longbody 12" travel in front, shortbody 12" travel in rear; 360/80 valving in front, 255/70 valving in rear $760.00 Kartek
CITI motorsports front coils $177.00 CITI Motorsports
Cross Enterprises inboard rear shock mount $126.00
Custom rear springs by Betts Spring, 11 leaf, soft spring rate $462.00 Betts Spring
Drop trackbar bracket $39.00 Wild Horses
Front full rise shock hoops with 3 mounting points; 1.5" tubing $170.00 All For Fun offroad
Sams offroad HD traction bar; w/ johnny joints at all 3 ends, gusseting, and "Slickrock" HD spring hanger (mount); 1.5" DOM tubing .375" thick $378.00 Sams offroad, 4 wheel parts
Wristed Radius Arm $224.00 Wasatch Steel, Metal Supermark
Brakes
Corvette 1 1/8" master cylinder 4Wheel disk brakes $64.00 NAPA
Corvette Dual Diaphragm brake booster $150.00 NAPA
Wilwood adjustable proportioning valve $40.00 Summit Racing
Extended brake lines $75.00 NAPA
Brake booster bracket $95.00 Jeffs Bronco Graveyard
Hard lines $25.00 NAPA
Steering
AGR 3 1/3 steering box conversion w/ Saginaw pump, 3.33 turn Scout/AGR box, new lines and all brackets $1,050.00 James Duff
Custom draglink with DOM tubing, cut and threaded $75.00 Local machine shop
Custom made March aluminum pulley (needed to align with the supercharger) $150.00 March pulleys
Duff steering box support/brace truss $75.00 James Duff
Perma-cool steering fluid cooler $30.00 Summit Racing
Power steering brackets $21.00 Junkyard
Tie rod over knuckle steering with 3/4 ton truck tie rods and tie rod ends, machining knuckles, etc $351.00 NAPA and local machine shops
Vibration Dampening U-Joint $0.00 James Duff
Wild Horses drop pitman arm $70.00 Wild horses 4x4
Hope that answers most of the potential questions.
