hello! i have a 74 ford bronco ranger in original condition. mechanically, it has been pretty good, but i can't seem to get this overheating problem fixed.
started with overheating while idling only.
replaced temp sending unit
then it really overheated, 230+ degrees, white smoke bellowing from hood
replaced thermastat (195 i was told), still happened
had mechanic put in (i believe 180) another thermastat
still problem, he took out radiator, sent it off to be tested, they said bad so replaced with new one
the general overall overheating fixed, but still overheats while idling (gets up in range of 210-230), starts droping down to norm, 195-200, once go
new water pump
mechanic read article about this problem in 72-74 models, suggestion of added auxilary transmission cooler didn't work
now we don't know what to do. he's put in fan shroud also.
one other piece of info, although i don't think it's the cause, there is a dealer installed AC. bronco overheats without turning on AC, but the AC radiator is in front of the engine radiator.
any suggestions would be great!
Thank you, Julie
Atlanta, GA
ps. i'll try to post a pic of my bronco
new water pump
Thank you, Julie
Atlanta, GA
