74 with 3.5 inch lift and 35 inch tires. Drives great but has too much positive CAMBER. Outside edge of tires wearing badly and positive CAMBER is very visible, even after installing adjustable ball joints.
If I were to cut and turn the inner C, is there enough clearance between the axle tube and the C to be able to correct the CAMBER?
I would want to be able to do enough correction to eliminate the 1.5 degree adjustable ball joint. I'm guessing about 3 degrees of correction.
Thanks guys!
Thanks guys!
