garberz
Bronco Influencer
What's the preferred method for setting the carrier bearing preload. I've seen some check the amount of case spread with a dial indicator. And others tell me "Run the side adjusters up snug, then after pattern and backlash are set, tighten side adjusters one more hole". I'd like to hear what you guys are doing.
Mark
Mark
