commonlaw said:
I will be installing a 4 core aluminum Ron Davis radiatior soon. I will need to plug the auto cooling ports and am wondering if what I need are the particular plugs that prevent electrolysis (aluminum or stainless steel), like the ones from WildHorses:
http://www.wildhorses4x4.com/11.asp
Also, I am assuming it is important to always used distilled water, correct?
Will I need a new fan shroad if mine is plastic?
If you're worried about electrolysis don't use tap water, use distilled water. If the solution is de-ionized, electrolysis can't occur (if the solution can conduct electricity electrolysis can occur).
As previously discussed the best way to combat electrolysis it to have a sacrificial metal (anode).
By placing disimilar metals into non-distilled water (or any other ionized solution, acid etc.) in contact with each other you are creating a battery. Depending on the types of metal and the solution, the current flow (which strips and plates) will vary.
Surface area ratios between the 2 metals will determine how fast each is stripped or plated.
If you used SS plugs the surface are ratio is so small that very little if any stripping of the aluminum will take place. Aluminum plugs would be neutral. Brass would be safer than SS.
Here is a good chart showing galvanic properties of metals.
http://www.metal-mart.com/Guides/Galvanic.htm
Pick any 2 and put them in a solution.
The higher one (one the chart) will disolve into solution and plate onto the lower one (on the chart). This chart illustrates why boats use Zinc or Magnesium anodes to protect their metal parts. As long as the anode is on contact with the base metal, the anode will dissolve (corrode) and protect the base metal.
