Greenflan2
- Joined
- Mar 7, 2019
- Messages
- 22
I’m in the process of replacing my passenger A pillar. Should I make sure the measurements from A pillar to B pillar are consistent at the top, middle and bottom and adjust/shim the door gap later or should my focus be on getting the door gap at the B pillar as perfect as possible before I weld in the new A pillar, even if it means the measurements from the A pillar to B pillar aren’t exactly consistent (they would be close)? My doors are original and may not be exactly straight or square at this point but I do intend to use them, for now anyway. I’m sure it could be done either way and work, just not sure which is the better or correct way. Thanks
