Advise on floor Hurst 3-speed shift boot cover
jake2077
Hey, guys. I have the shift linkage and related things settled for the Hurst shifter and it drives fine. I'm wracking my brain trying to come up with a decent cover and boot to clean this up and keep out the heat/air/etc.. I purchased the metal box type fitting from Toms Offroad but due to shotty body work it does not line up even remotely to make it worth the effort. Looking for suggestions or other solutions others may have done in this case. Thanks!
bfoldy
Torrance, CA
It's kind of hard to tell from the one picture why the tunnel cover supplied doesn't match up to your floor in that area, but do you think you could make the metal tunnel cover work by bending and trimming? If not, you could always try making your own from scratch using sheet metal and cutting and bending it to match the contour of the floor. Most of the other suppliers offer the cover in fiberglass, but metal one from Tom's might be the easiest to work with.
GloNDark
I had to bend and trim mine ALOT to fit properly with the floor. It's still not perfect but it's close enough to drive and get the rest of the bugs out.
GetAttachmentThumbnail
jake2077
jake2077
I had tried to see if bending would work but the hole in precut Tom's Offroad would have to be opened even more.
.94 OR
I used to have the 3-speed on the floor. It had the fiberglass cover and a Hurst boot. The boot was pretty stiff (thick and old) and had compacted as flat as possible. This caused the boot to tear so the shifter itself would extend past the opening in R & 2. Not a huge deal, but looked rough and allowed cold and dirty air in during those times.
Now that I have more tools and funds, I would install nutserts in the floorboards to anchor the cover down with regardless whether it was fiberglass or metal so it would make securing it easy and have a tight fastener.
Good luck on getting something to fit.
fluffybunny
Newbie
I made mine by making a template from 24 can drink packages and then traced them on sheets of metal from Home Depot. Luckily my next door neighbor had a small brake so I was able to get some straight bends on a couple of the pieces. Then I tacked it and sprayed bedliner on it. Total cost was about $40, excluding the bedliner material I already had. 20220530_143142.jpg 20220601_180811.jpg 20220605_132016.jpg
jake2077
jake2077
Made my own shifter covers
Sent from my SM-G981U using Tapatalk
Nice! I have a neighbor who does his own metal work and has a CnC machine. Think we're going to try and fashion up a frame then 'create' a leather boot for each. Will post pictures when done hopefully soon! Thanks everyone for the ideas!
chrlsful
nice!
I would made it big enuff for both. Used nuts to make remove/replace like other companies of the era
and used the same eustachian/boot idea U have (or heavier duty, also remove/replace style components).
Some of those plates are pretty big. U can really do some work thru them once removed. May B I’m showin
my nautical heritage? aahahaha
