Another where-to-put throttle body fuel lines
omureebe
So I can see that many, if not most, people that run a throttle body EFI are running the 3/8" lines (supply and return) on the inside (or top) of the driver's side frame rail. Is there a reason why it's this way versus outer driver's side rail, or inner passenger side?
As I'm in putting in my new tank with FiTech retrofit pump and running lines, my dual exhaust on the driver side is really close to the inner driver side rail. And the floor supports are a lil crunchy, and trying to make hard line fit on top doesn't look right. So I'm thinking why not run on either the outside of the driver rail or inner passenger side. Looking for input with folks that have done this.
Omar
904Bronco
San Martin, CA
Omar
5/16" fuel line (metal or EFI compliant hose with a protective liner) is of the proper size to support 300+ HP. Most people do run 3/8" feed line as it is easy to do the 1st time, the cost is a little more than the smaller and most plan HP upgrades.
Most Ford EFI engines have the fuel rail supply and return lines on the Driver's side. Exception being 87-93 Mustang systems. So the Driver's side is where people run those lines.
Exhaust, I don't follow trends much, but I think a lot of bronco owners are running a two into one system that follows the factory path for the exhaust. This also keeps a source of heat away from the fuel lines. So having the fuel lines run on Drivers side makes sense.
Running fuel lines on the outside of the frame creates a possibility for damage while wheeling, the lines are better protected inboard.
My opinion is that if you can run the lines on top of the frame, it is the best place and provides the best protection. It is, however, difficult to do without a body lift and/or frame off.
omureebe
omureebe
Good points... Right now it's a 302 with dual exhaust, but I have a mildly built 0.040" over 351W (edelbrock heads and intake, RV cam, etc) on my stand that I'll put in next winter with the 2-into-1 exhaust, so 3/8" I'm def doing. But going on top of the frame rail looks more than difficult with the crunchy floor supports. I didn't think that the 2-in-1 may rule out the passenger side rail!
tasker
all knowing of nothing
NH
left side of frame on my 351 build rig
tasker
NH
;D only temporary! a little further along than that pic!
omureebe
omureebe
Another question on your setup.... Looks like you're running rubber hoses all the way. I was thinking about doing this due to ease as well as less fittings, versus rubber to steel, steel along most of frame rails, back to rubber up to filter then throttle body. Any concern with running all fuel rated hose? And thanks!
tasker
NH
only in CT! come on up sometime! actually hard to tell but it is steel fuel line just after that low pressure pump. I do have some injection hose to tie everything together but majority is steel
omureebe
omureebe
Yeah I want to get this done so I can make it to a May It Forward! It's been at a shop for 4 years so I pulled it back and need to finish this truck up!
sanndmann3
I bought the ptfe lined ss jacketed flex hose and ran it thru the drivers side frame rail.
